News
Symantec software boots users offline
A faulty update to Symantec's Norton security software began booting thousands of users off their AOL internet connections last week, Symantec has admitted. Read more
Vista Gets Hacked, Linux Remains Unbroken In Contest
Vancouver (WA) - Over the weekend, a hacker managed to exploit a vulnerability in the Windows Vista Flash player, as part of the CanSecWest's "Pwn2Own" contest. Read more
ATI Catalyst drivers have a problem
ATI has a problem in the latest Catalyst drivers. Read more
Acer readies full range Vista-certified LCD monitors
Ahead of the official launch of Windows Vista operating system (OS), Acer now offers a full range of LCD monitors, with sizes ranging from widescreen 20, 22, 24 to 26 inches, ready and tested by WHQL (Windows Hardware Quality Labs) for Windows Vista compliance, according to the company. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
System Builder Marathon: $2,500 Enthusiast PC
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
System Builder Marathon: $1,250 Mid-Range PC
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
SSDs Replacing HDDs Soon? Not A Chance
Some say 2010 and even 2009 will be the year of SSDs. We think not. Read more
All the Reviews & Articles
  Tom's Hardware Forums » Overclocking » AMD » overclocking problem booting xp/vista
Word :   Username :
Bottom
Author
 Thread : overclocking problem booting xp/vista
Profile: journeyman
More Information
OK I'm new to overclocking but I've been reading forums all over the internet and while I've learned alot i can't seem to find a fix for my problem. I set my multi to 10 and my fsb to 250 for and effective 2500mhz/500mhz ram.
When I do this i can boot into windows xp MCE but not windows vista 64 ultimate. Also with the multi set at the stock 11.5 i can't get the fsb over 233.
Here are my specs, can't remember everything and I'm at work right now and can't look.
Motherboard: biostar T7025
CPU: AMD 4400 brisbane
Ram: Crucial Ballistix(Cpuz says it will do 400 or 500mhz with the correct timings which i set for the speed i wanted)
VGA: MSI HD2600Pro, fanless cooling.
One last thing off this particular topic. Can anyone provide a link about flashing my hd2600pro to an xt or give me and info/addvice?
Thanks
Related Product
Profile: Forum Veteran
More Information
Can the pc boot Vista at stock? Does it pass memtest at stock?
If yes to both, then what's your ram divider? If you can, post your max stable HTT, RAM & CPU speeds.
Profile: journeyman
More Information
I've ran the bios memory test 4 times at my desired setting and they all came out good. I'm going to d/l memtest and see what turns out with that. Yes it does boot vista at stock thats what I'm normally running for my OS. I lock my HTT at 4. My ram divider at multiplier 11.5(stock) is 6 and at multiplier 10 divider is 5. The epp for my ram says 5-5-5-15-30@500mhz,however my bios will only do 5-5-5-15-26.
My stock clock speeds are:
11.5 * 200=2300(I can get to FSB230 but would like to go higher)
I would also like to get to
10 * 250=2500 so that I have a slight overclcock and still get my ram at full speed.
More Information
If your ram divider is 6, then your ram speed is:
CPU GHZ / RAM DIVIDER = DDR2 MHZ * 2
2500 / 6 = 416.66666666666666666666666666667 * 2
Your ram will be at 833mhz more or less. cpuz doesn't always read the right ram speed out. It does mine though.
How did you come to the current overclock? Normally, you find the max htt, ram & cpu speeds, then set the htt & cpu multi from the max cpu speed & use a ram divider to match ram speed to your max ram speed. In other words, if you came to the current o/c that way, you may be hitting a limit. You can either up the voltages or be happy with the o/c.
You can try lower multiplier & higher htt.
Profile: journeyman
More Information
when I set my multiplier to 10 it changes my ram divider to 5, thus
10*250=2500, 2500/5 =500mhz*2. thats where i want my ram but anytime my FSB is over 230 vista won't boot. Even if I raise/lower my mulitpier. Hope I'm being clear enough. I'm downloading some bench marks and im going to try and stress test it in xp to see if its stable there.
More Information
I assume your cpu multiplier is x4? The HTT will be 250 * 4 = 1000mhz. It should be fine. Even up to 1300mhz for AM2.
Oh yea, if you change your bios settings, vista may not like it cuz it thinks it's a different computer. MCE & XP are more flexible. How about you set up your target o/c, & boot up vista install disk?
Profile: journeyman
More Information
Thats a good Idea, I'll try that.
Google Ads
