Hi everyone
This weekend I put together my first computer in about 3 years, and I have some questions for everyone about it.
First off, here are the specs
Case: Apevia X-Discovery with top 80mm fan and side 80mm. 500W power supply
Processor: Core 2 Duo E 6750
Video: Evga 8800 GTS Superclocked
Ram: 2x1G kit of Patriot Extreme Low latency PC-6400
HD: Seagate 320GB 7200RPM 16mb Cache
Mobo: Gigabyte P35-DS3R
Windows Vista Premium 32bit.
Ok, those are the specs. I basically got great deals on everything after I did a lot of driving and shopping around (and a lot of research here).
Here are my questions, and let me thank you in advance for any advice you can give.
1. Cooling: I haveheard from many people here that the 8800 GTS is going to run hot. I have two questions here: With my two fans and that case, do you think I am going to have enough cooling to have a good performing stable system? And I don't plan on doing much overclocking, but if I do, what would you recommend for low cost cooling improvements?
2. Upgrades: I have read great things about the video card, and the Mobo will allow me to expand to quad core and the new Intel chipset when it comes out. Do you see, or have you personally experienced any big limitations that I am going to encounter?
3. Optimization: I am running everything stock out of the box. If you have used any of the stuff I am using, do you have any suggestions for quick optimizations I could make for improved performance?
Again, thanks for your time, I look forward to hear what you have to say.
JerBu.
JerBu.
