News
Polysilicon Spot Price Posts Mild Drop
Despite the spot price of polysilicon still remaining high, a mild weakening sign has been seen over the recent month. Read more
GPS can help give early warning of tsunamis
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
MIT researchers developing a quarter-sized turbine engine
MIT researchers have started putting entire gas-turbine engines on tiny silicon chips. With the help of some military funding, researchers have fashioned millimeter-sized compressors, combustion chambers and turbines and placed them on layers of silicon wafers. Read more
PhD Student Makes World's "Most Advanced" Walking Robot
Delft (Netherlands) - A PhD student at the Delft University of Technology in the Netherlands has constructed what he says is the world's most advanced walking biped robot. Read more
Latest Reviews & Articles
AMD Phenom II X4: 45nm Benchmarked
Can AMD finally recapture its former market lead with the Phenom II? We tested their new 45-nm CPU, which is compatible with AM2 motherboards. How do things look from performance, energy consumption and overclocking perspectives? Read more
Best Graphics Cards For The Money: Jan. '09
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Scorpio Blue: Big Notebook HDDs Go Mainstream
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
Value In SLI? GTX 260 Core 216 Vs. GTX 280
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
All the Reviews & Articles
  Tom's Hardware Forums » CPU & Components » CPUs » Urgent help
Urgent help
Word :   Username :
Bottom
Author
 Thread : Urgent help
Profile: member
More Information
I just finish builting my computer couple of hour ago computer
spec are-
q6600 go stepping -thermalright 120 extreme with S FLEX 120mm fan
P35 Ga DS3P mobo
2 gig of ram
500GB hd
pc power cooling 750 watt psu
ati 1950 pro
TT armour 8000 case
When i press start button it stays for 2 second on then it shut downs automactic and turns it back on for 2 second and shut down again.
I look at cpu fan its not moving, I plug in cpu fan to another connecter the fan works but same thing shutdowns in 2 second. what could be the problem?
Message edited by mario2008 on 08-22-2007 at 05:57:09 AM
Related Product
Profile: Honorary Poster
More Information
The fan not moving is likely due to a thermal monitor that turns the fan on only when needed.
As for the computer turning off and on.....It's time to do the usuall trouble shooting process. Unplug everything but the bare essentials, and see if it boots. If not, remove the mobo from the case and see if it boots on cardboard.
Profile: member
More Information
http://www.tomshardware.com/forum/ [...] -boot-help
this guy had same problem as me compter turning it on and off he says its a overclocking safey features? whats that i dont get any beep though.
More Information
Do what I told you, and you'll figure out the problem. Troubleshooting computers is easy...it's not like we're talking medicine here.
Profile: Forum Veteran
More Information
joefriday wrote :
The fan not moving is likely due to a thermal monitor that turns the fan on only when needed....
No, he's talking about the CPU cooler fan, which should always be on.
For the OP: One possibility for your problem: some MBs have a safety feature that monitors the speed of the fan plugged into the CPUFAN header and shuts down the system automatically if the RPM detected there is not "fast enough". By default, it is setup for the OEM Intel CPU cooler; some aftermarket coolers with larger diameter fans don't spin as quickly and thus may make this feature think the CPU cooler is not working properly. The feature can normally be adjusted/inactivated in the BIOS, but you may need to connect a faster-turning fan to the CPUFAN header temporarily to "fool" the system.
everyone should run a i7 920 at 4GHz
Profile: Ancient Poster
More Information
try hooking up the 4 or 8 pin atx to your mobo!
If it ain't broken, modd it!
Profile: nimble knuckle
More Information
I had several machines with the same problem:
- some were due to fried mobos, even when right out of their package,
- others were due to failing PSUs.
Eliminate the second by switching PSU; if not, swap the mobo.
Efficient coding leads to impressive software; sloppy coding leads to Vista.
Profile: enthusiast
More Information
To dragonsprayer: LOL! That's a VERY good thought. I didn't think of that one myself. I know it seems really dumb, but everyone forgets the simple stuff sometimes.
To mondoman: Your post makes logical sense, but at the same time, I have to wonder what crappy company would be THIS limiting? Sell you a MB that protects you from breaking the CPU(like the MB company really cares THAT much about YOUR CPU) and at the same time can screw a customer that bought a tray CPU and aftermarket fan and their MB doesn't work. If I tried swapping out all the other parts I had spares of and realized it was the MB, I'd RMA it. When I got the new motherboard with the same problem, I'd change companies and swear that company X sells really crappy parts. What I would expect is maybe a reboot when the CPU hits the BIOS temperature threshhold or an error message when the computer is POSTing. I just can't imagine a company would be so bad to do that to their customers. Let's not talk about water cooling either.
Joefriday is possibly right that the thermal monitor turns the fan on only when needed, but it could also be a sign of whatever the problem is(bad MB?)
I would try stripping the computer to minimum to POST the machine and see what happens. Also check your 4 or 8 pin power cable and make sure it is connected.
More Information
I'm well aware of what he's talking about. The CPU fan will not always spin on certain mobos. I believe the DS3 is one of them.
Profile: member
More Information
i took out the cpu and heaksink from the mother and click start button it was running fine without restart like normal :pt1cable: what could be the problem?
Profile: addict
More Information
You mean it's running without a CPU?
Message edited by Jim_L9 on 08-22-2007 at 08:54:56 PM
Profile: member
More Information
yeah just notice thermalright 120 extreme might be touching the mother board heatsink to close together maybe
Message edited by mario2008 on 08-22-2007 at 09:02:15 PM
More Information
First time I've ever heard of a mobo booting w/out a cpu...
Profile: member
More Information
yeah there was no screen on my monitor or anything but without cpu and heatsink mobo was running.
Profile: journeyman
More Information
Running without a CPU..........................?
Screw the Intel AMD war......Sounds like theyre both going to be out of business soon.
OCZ GameXStream 700W PSU
Intel C2D E6600 @3.0ghz
EVGA 8800GTS 640MB x2
2x1gig Patriot eXtreme PC6400 RAM
Profile: member
More Information
i mean to say system doesnt turn after i took out the cpu and heaksink but after reinstalled the cpu and heatsink it keep restarting every 2 second :(
Profile: member
More Information
n°1740876
08-22-2007 at 11:13:22 PM
