Gainward has just confirmed that it is working on 512 MB version of 6800 Ultra card. Read more
ATI says it will demo the first graphics card with 512 MByte memory at the Ultimate LAN event, held in Dallas from February 25 to 27. Read more
Nvidia expanded its product lineup with two new news graphics processors for the high-end and the low-end. Read more
High-end gaming still is niche-market, but growing demand prompts card manufacturers to extract additional performance from existing architectures. Read more
Do you remember the stereo glasses that were around about 10 years ago? Now that 120 Hz LCDs are starting to pop up, Nvidia is teaching an old dog some new tricks with its GeForce 3D Vision shades. Read more
Can AMD finally recapture its former market lead with the Phenom II? We tested their new 45-nm CPU, which is compatible with AM2 motherboards. How do things look from performance, energy consumption and overclocking perspectives? Read more
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
| Bottom | |
| Author |
Thread : 6800 Ultra power problem ??
Profile: stranger
More Information
Hi,
Related Product
Profile: Faithful Poster
More Information
Check and make sure any power leads are conected properly and that the card is seated properly in its slot other than that it could be any number of things ie MOBO degrading of your PSU.
Profile: stranger
More Information
Pulled the card out and put it in again and made sure that all was coneccted didnt work |
"Hmmmmmm"
Profile: Honorary Poster
More Information
Hide
Display/Hide instant messengers
IT'S time to upgrade,,,, |
Profile: stranger
More Information
thats not what i asked |
More Information
iTs Me
Profile: addict
More Information
maybe your psu is crapping out. time for a new psu?
Profile: stranger
More Information
Profile: enthusiast
More Information
try re setting the cmos? all so you have not included you power supply.
Profile: stranger
More Information
cmos gives no results |
Profile: stranger
More Information
what do you guys think is it the mainboard or the gforce ? |
Kitteh iz watchen!!!!
Profile: addict
More Information
tell us your psu and then we can help you..it can degrade over time...tell us the 12v amps etc.. --------------- E6300@3.2ghz 1.32v | Gigabyte P35-DS3R 1.0 4x1GB C5@900Mhz | 8800GT |
Profile: enthusiast
More Information
That sucks.
Profile: stranger
More Information
its not the psu i thougt that at first to so i put a new one in same problem |
Profile: stranger
More Information
put a 7300gt in today same problem so its not my card |
Profile: enthusiast
More Information
yep sounds like it. if you want to make double sure you could replace the power connectors that plug into your motherboard. |
Profile: Eternal Poster
More Information
Gotta be you PSU. If it is a 650 watt generic then it really aint 650 watt. Dont matter if its 10,000 watts if the +12v rail doesnt have enough amps it wont work right. If its not the PSU I'd say you got a virus. I really doubt the mobo is bad unless you se some bulging or leaking capacitors. Try doing a reformat if we can comfirm the PSU is good. And check the web for a new updated bios. |
