I have a Gigabyte GA-M61P-S3 motherboard and the temp reading seems to be a bit high. I have an AMD X2 3600+ clocked to 2.6ghz from a 70mhz fsb increase. The idle temp reading for the motherboard is 38 and load is 52 (Orthos). I recently replaced the NB passive heatsink with a much larger Cooler Master heatsink :
Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128034
Heatsink
http://www.cluboverclocker.com/reviews/heatsinks/coolermaster/BlueIce/index.htm
After installation the temps are 37 idle and 48 load. I was expecting a bit more of a jump because the heatsink is much bigger and I have a 120mm fan pointed right at it. One thing, I forgot to remove the thermal paste from the old heatsink when I put the new one on, would that be a large detriment to the cooling? Also, would not using a more high performance thermal grease like Artic Silver cause only a mediocre increase in cooling?
And as a last question, I am getting a PCIe graphics card soon, since the 6150LE chipset inside the northbridge will no longer be in use is it reasonable to expect the temp to go down?
Thanks
Andrew
Mobo
Heatsink
Thanks
Andrew
