Tom's Hardware > Forum > Storage > Hard Disks > SATAII Western Digital possible problem
Forum Storage : Hard Disks - SATAII Western Digital possible problem
Hi,
I recently built a new computer with the following specs:
MB: Maximus Formula ASUS (didn't do BIOS update)
CPU: E6850 (no overclock)
Video: 8800GT 512
HDD: SATAII Western Digital 500 gig
RAM: TWINX2048C4DHX
PSU: OCZ 850WATT
CASE: ANTEC 900
Sound: ASUS FX Supreme 2
Problem: After putting everything together with no problems, fixed minor things in the BIOS for my advantage, doing no overclocking, BIOS recognized my HDD 500 gig WD SATAII and my SATA DVD burner with no problem. When I'm about to install WINXP PRO (32-bit), I get to the screen where you press "enter" to install WINXP, "R" to repair or "X"(or something) to exit. So I press "enter" to install WINXP, get please wait, then my machines reboots, then DVD finds winXP cd, then I'm back to the screen where it says press enter to install WINXP. My question is, how can I fix this or what could cause this? My mobo detects to HDD. Could it be a HDD issue?
Thanks,
Chris
Sponsored Links
Maybe the WinXP setup doesn't see the hard drive. How did you configure your hard drive in the BIOS? IDE,Sata,Raid?
Reply to cfvh600
I configured the SATAII drive in the BIOS as IDE since I won't be using RAID and which was noted in the motherboard manual.
Reply to chris2424
So that can't be the cause of the problem. :pfff: Your XP disc not scratched or dirty?
------------------------------ AMD4200+X2 S939,Albatron KM51G,2 x Corsair CMX1024-3500LLPRO,8800GT 512MB,Thermaltake TR-2 500,WD 250GB SATAII 16MB,Soundblaster Live! 24-bit
Reply to cfvh600
XP disc is not scratched or dirty. I've read some threads elsewhere where you need to install the SATA drivers since XP setup might not/or would not recognize SATA drives. This could be the case right???
Reply to chris2424
In fact, it was bad ram the problem after all. Thought it was the HD, but wasn't.
Reply to chris2424
There are 1119 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
