First time putting a gaming rig together. I have modified/upgraded pre-built systems but I am doing this one from the ground up. I have searched and most sites tell you what parts to buy. I am looking for the RIGHT way to put them together. Anyone know of a quality guide/site they would recommend for the right way to build your rig?
Also, here is my build what do you think? Thanks for the help with both questions.
Motherboard: Asus Striker Extreme (I know retail it is way too expensive. My buddy hooked me up with one for only $200--do you think it is good for that price?)
CPU: Intel Core 2 Duo E6850 /w/ Thermalright Ultra 120 Extreme for cooling
Power Supply: Antec 650W TruePower Trio TP3-650 EPS12V (I see some of you aren't Antec fans, but I got it for $60-I have heard it is a decent power supply but what do you think?)
Hard Drives: 2 x Western Digital Raptor WD1500ADFD 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive
Optical Drive: Lite-On 20x DVD+RW/-RW LH-20A1S SATA
I think those are the main parts--using a G5 mouse, etc but the above are the guts. Thanks again for your help pointing me towards a good guide for putting all this electronic goodness together.
MAKE SURE ALL THE STANDALONES ARE INSTALLED !!!11 DO NOT LEAVE ANY OUT (lol bad experiences) also a tiny bit of advice, at canadian tire or a ford dealership, they sell those blue Motomaster rubber mechanics gloves, which are disposable. greatest thing ever since you can grip each piece with the utmost control, and you dont need to worry about shorting anything out ^^
They are called "standoffs" not "alones"
------------------------------E8500,GA-EP45-UD3R, 8 GIG MUSHKIN, XFX 4890 , ASUS 22", WD 640 X 2, CM 532, CM 650TX
Reply to royalcrown
