News
GPS can help give early warning of tsunamis
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
MIT researchers developing a quarter-sized turbine engine
MIT researchers have started putting entire gas-turbine engines on tiny silicon chips. With the help of some military funding, researchers have fashioned millimeter-sized compressors, combustion chambers and turbines and placed them on layers of silicon wafers. Read more
PhD Student Makes World's "Most Advanced" Walking Robot
Delft (Netherlands) - A PhD student at the Delft University of Technology in the Netherlands has constructed what he says is the world's most advanced walking biped robot. Read more
America's Largest Apple Store Opens Its Doors
his morning saw the official opening of Apple’s latest flagship store in downtown Boston. Read more
Latest Reviews & Articles
GeForce 3D Vision: Gaming Goes Stereo
Do you remember the stereo glasses that were around about 10 years ago? Now that 120 Hz LCDs are starting to pop up, Nvidia is teaching an old dog some new tricks with its GeForce 3D Vision shades. Read more
AMD Phenom II X4: 45nm Benchmarked
Can AMD finally recapture its former market lead with the Phenom II? We tested their new 45-nm CPU, which is compatible with AM2 motherboards. How do things look from performance, energy consumption and overclocking perspectives? Read more
Best Graphics Cards For The Money: Jan. '09
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Scorpio Blue: Big Notebook HDDs Go Mainstream
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
All the Reviews & Articles
  Tom's Hardware Forums » General Networking » Network General Discussions » Problem Unknowned - Help, help, help
Word :   Username :
Bottom
Author
 Thread : Problem Unknowned - Help, help, help
Profile: stranger
More Information
Hi ppl, for the last 10 days i tried to solve a weird problem, that appears over thin air.
I have a 1MB connection, that works fine with browsers like IE, Firefox, Safari,opera. I can make total use of my bandwith if i download from a ite using a browser,but,´
when i use some kind of p2p(i try emule, azureus,dc++,grabit(newsgroups),shareaza), my down goes to a maximum of 5kbps and my up goes to top 3kbps.
I disable all the firewaals , including the worm protection of norton 2007. i´ve change the tcp and udp ports several times and nothing.
I´ve istaled several programs to boost p2p connections like limmeware ultra, and nothing
. I´ve searched over the web including the d-link forums and find nothing about this situation
10 days ago it was working just fine. i didn´t install any new software. i´ve formated my pc but the problem is still on
my modem is a d-link DWL-G700AP
Please Help
Marcus
Related Product
Profile: member
More Information
do you have the proper port forwarding configured on your router? the super slow download speed like that with BT or similar programs normally indicates issues with that.
Make sure all firewalls are disabled.
Make sure the ports you set it to use in the program are forwarded to your pc in your router setup.
Those two steps should fix it.
Profile: stranger
More Information
like i said before, all my firewalls are disable and i disconnect the router and the problem is still on.
Thanks for the reply
Profile: stranger
More Information
i´ve tried in 2 notebooks and iget the same problem, p2p software of any type goesto a max of 5kbps.
my service provider said that they aren´t blocking any port.
Does anyone have the same problem???
OW!
Profile: Honorary Poster
More Information
your not gonna get an answer here as we do not support piracy...... (ure downloading from other peoples computers thats why its slow)
Profile: Faithful Poster
More Information
Quote :
Just because they say so doesn't mean that they aren't.
Anyway you are dependent on the other computers upload speeds.
Profile: stranger
More Information
the problem is still on. My list of progrmas that i can´t use is growing.
now it starts afecting skype and voipbuster
Profile: stranger
More Information
well i found out what is causing the problem , but i can´t solve i.
thanks to all, specially flakes
Google Ads
