For some users, computer designs can't be small and quiet enough. Mini-box.com has begun offering what it claims to be the world's smallest ATX compliant power supply that uses a single 12 volt power source and puts out 120 watts. Read more
Thermaltake now offers a high performance power supply for users that just can't get enough power. The new model belonging to the Toughpower line provides up to 2 Kilowatts of power. Live demonstrations are given at the company's CeBIT stand Read more
OCZ Technology Group has introduced a new modular power supply with a sustained output of 600 watts. The PSU will hopefully lessen cable clutter because only the necessary power cables need to be attached. The titanium mirrored case comes with two PCI-Express cables and a 4/8 pin CPU auxiliary fan connector. Read more
Thermaltake announced recently that three new products in its PC case, power supply and cooling system lineups have recently received Nvidia ESA (enthusiast system architecture) hardware platform certification from Nvidia. Read more
Most modern drives can be set to deliver maximum performance or to operate quietly. We looked at how performance, acoustics, and power requirements change when switching from fast to quiet using Hitachi’s Deskstar 7K1000.B. Read more
AMD's 790GX and 780G support onboard memory to help improve the performance of integrated graphics. Is it worth paying a bit extra or is the feature a mere gimmick? Read more
Does your aging CrossFire-compatible motherboard have enough PCI Express bandwidth to make a second card worthwhile? We compare every Core 2-based platform in order to find out. Read more
Intel's Celeron-based SS4200-E is the company's latest effort to clinch market share in the SOHO storage space. Is it enough to usurp more established incumbents? Read more
Tom's Hardware Forums »
CPU & Components
Power Supplies, PC Cases & Case Mods »
can i use a 20pin power supply in a 24pin slot?
| Bottom | |
| Author |
Thread : can i use a 20pin power supply in a 24pin slot?
Profile: member
More Information
Bought some new pieces to upgrade my system (mobo,cpu, ram, hd) and i forgot to take into account the power requirements.
Related Product
BAM!
Profile: Ancient Poster
More Information
I have actually seen a 20 pin PSU running a 24pin mainboard system, although i would recommend against it as its under powering the board and could cause instability and possibly hardware damage.
--------------- "This thread made me strap on my lolerskates and head for my roflcopter." |
Profile: addict
More Information
You can buy an adapter to take the 20-pin and turn it into 24-pin. You don't need anymore power then what you already have at the moment, so buying a new PSU wouldn't really be the most economical option until you need the extra power. The adapters are in the range of $2-3, and as with all technology, a better power supply will be cheaper by the time you upgrade to something that needs more power. Message edited by Gravemind123 on 08-24-2007 at 07:57:25 AM |
Profile: nimble knuckle
More Information
Even with the adapter (and I have one in my junk box), the old PSU may not have enough output on the 12 volt line.
Profile: stranger
More Information
Hide
Display/Hide instant messengers
Just read your motherboard manual and it will tell you if you can and which pins to use.
Profile: member
More Information
thanks for the feedback. The mobo i have is a asus P5K SE board. PSU is thermaltake silent power 480w. What specifically do i need to look for in the manual? I'm not too knowledgeable on power supply details.
Profile: member
More Information
I tried to use an Antec 480W with 20-pin connector on a P5B with a 7600GT graphics card, and whilst it booted to windows without problems, any slight stressing of the video card resulted in video corruption and eventually a lock/crash.
Profile: addict
More Information
I've been using a 20->24-pin adapter on my current setup for a while now, and I have never had an issue. My powersupply is a 600W single 12v with 37A. You have a 480W single rail with 18A. Although that is much lower spec, the 7600GT shouldn't be all that power hungry. I suppose if you plan on upgrading soon anyway you could go out and buy a new power supply as you will need one in the future, or you could give the adapter a try and see how it works. Oh, I also have used this same power supply with just the 20-pin connected and it works fine also. |
More Information
Yes it will.As long as the psu has enough amps n the 12volt rail,you should be good to go.In fact one of my systems does exactly that.I'm currently using a 450watt FLOWER PSU,along with a 20 to 24 pin adaptor.So far everything works well.It has a 4400+ X2 cpu as well as a 7800gt and the other usual hardware.Goodluck.I do however reccommend upgrading to a proper psu.
Profile: member
More Information
ok well i'm going to try either later tonight or probably tomorrow in putting it all together. if it boots and runs, cool. If not, i'll just go pick up a new power supply. They arent all that much money so it's not that big a deal. another 480-500w psu looks like it'll run me $30-$60 |
Profile: old hand
More Information
If you do decide to purchase a new PSU - you might want to consider an Antec Earthwatts 500W PSU. I just purchased one online from Frys on sale for $49.99 - NO rebate required - marked down from $89.99. A real deal. The Frys stores in San Jose CA area also have the same special in their stores and you save the shipping - I bought mine online and paid $8 for ground shipping. By the way - this unit is certified to have 80% or better efficiency accross most power ranges.
Message edited by rockyjohn on 08-24-2007 at 06:26:20 PM |
I still have my PPro
Profile: addict
More Information
You can buy an adapter to take the 20-pin and turn it into 24-pin. You don't need anymore power then what you already have at the moment, so buying a new PSU wouldn't really be the most economical option until you need the extra power. The adapters are in the range of $2-3, and as with all technology, a better power supply will be cheaper by the time you upgrade to something that needs more power ;^) |
CPU & Components
