News
CeBIT 2008: Three new ASUS Motherboards for AMD CPUs
ASUS is introducing three new motherboards for the AMD platform at this year's CeBIT - the M3N-HT Deluxe/Mempipe, the M3A32-MVP Deluxe/WiFi-AP and the Crosshair II Formula. All three boards use socket AM2+. Read more
AMD and Intel supported on same motherboard
Hexus.net has a post and pictures about ECS, which exhibits at CeBit its ECS PF88, the first mainboard to support both Intel P4 AND AMD Athlon 64 processors. Read more
Nforce 3 to come in PCI Express flavour
Nvidia is putting its Nforce 3 chipset on the PCI Express. Read more
Biostar unveils Nvidia nForce 500 series motherboards for AM2 platform
Biostar Microtech on May 23 introduced its new T-series motherboards supporting AMD's AM2 platform and nForce 500 series chipsets, the TForce 590 SLI Deluxe and TForce 570 U Deluxe. Read more
Latest Reviews & Articles
Roundup: Six Core 2 Motherboards Under $100
As Intel’s Core i7 architecture starts moving down from the high-end, value seekers can build high-performance LGA775 systems cheaply. Low-cost motherboards compete for the value crown with added features, performance, and overclocking capabilities. Read more
Radeon 4870: Does It Matter Who Made Yours?
Once you’ve found the GPU that best fits your needs, does it really matter which vendor sells you the card? We take a look at AMD's reference 4870, Sapphire's, and Palit's to get a better sense for what differentiates graphics cards. Read more
Highpoint Takes On Adaptec's SAS Controller
Professional hardware can be expensive, but are cost effective business products really an alternative? We compared Highpoint’s new RocketRAID 2640X4 SAS RAID controller with Adaptec’s 5405 entry level card. Read more
GeForce GTX 295 Performance: Previewed
After a frustrating second half of 2008, Nvidia is looking to start the new year off by reclaiming its single-card performance crown. We got our hands on an engineering sample GeForce GTX 295 to give you a taste of what you can expect in two weeks. Read more
All the Reviews & Articles
  Tom's Hardware Forums » Homebuilt Systems » New System Build » No Post or Beeps with P5K Deluxe/e6750/2 gigs OCZ...HELP!
Word :   Username :
Bottom
Author
 Thread : No Post or Beeps with P5K Deluxe/e6750/2 gigs OCZ...HELP!
Profile: stranger
More Information
Hey all. I just put together a nice new rig:
Intel e6750
ASUS P5K Deluxe/wifi
OCZ Platinum Revision 2 2GB (2 x 1GB), DDR2-800, 4-4-4-15
OCZ GameXStream OCZ600GXSSLI ATX12V 600W
BFG 8800GTS Overclocked
When I first put this together...everything ran fine. I manually set the BIOS to the proper settings, and also upgraded to the latest bios (0501 Beta). Since then, a week has past.
A few days ago, I noticed that when I turn the power on, the system would begin to boot...then before POST, would shut off....then start back up a few seconds later. It seemed strange, but when my system booted, everything ran just fine. The problem has since gotten worse. This morning when I turned it on...no POST, no Beeps, but all my lights were on, fans turning, HD's running, but didn't go anywhere. After about 6 tries, it booted into windows and ran perfectly.
Anyone know what this might be? I have read on a few other forums that it can be the PSU, motherboard, ram, CPU.....=P....I would hate to RMA EVERYTHING I just got. I really want to narrow it down (I'll do memtest this afternoon to at least count the ram out).
Any help would be great!
Related Product
Profile: journeyman
More Information
I thought I remember hearing something about a MOBO issue (not sure which one exactly) but they said the MOBO would cause the computer to turn off and then back on at startup. It was fairly "common" with the board as lots of people had reported the same problem. I am not saying that is what YOU have but it MAY be......
Profile: journeyman
More Information
Try and re-seat your components one by one. Start with the RAM: Try to boot with just one stick, if it works, then try the other. If you have no changes there, then you know it is most likely not your RAM. If you are getting power to your MOBO but not getting the post beeps, it just means that something in the check list on power-up did not pass, so your PC will not power up to avoid damage.
You can also try re-seating your processor and CPU cooler. Sometimes, things come loose.
Profile: stranger
More Information
I'll start resetting everything when I get home and test a few things out.
It just seems weird that this morning after 6 tries to start the thing up, everything ran absolutely fine (heck, I even managed to get a few mins of BioShock in).
I'll post back with my findings...cause apparently, I'm not the only one.
Profile: stranger
More Information
Ok, after unhooking everything from my motherboard and putting things back one by one....I'm confident that this problem is coming from the SATA ports.
It was weird how I got to it. I removed the memory first then powered on....no beeps, but everything turned on....next the GPU...same thing...no beeps, everything still on. Next I took out the CPU....ya think that would make the motherboard beep...Nope!
It was really taxing my brain, so I pulled off everything that was giving life to that motherboard and attached everything one by one. Low and behold, I got beeps! Eventually, I got to the point where when I plugged in a SATA cable (didn't even have to be attached to a drive), nothing...no beeps, no love.
I still have a problem though...I want to avoid RMAing this thing until I know for sure it's completely dead on me. I'm hoping it's just a BIOS setting or faulty cables. And apparently, others are getting SATA probs on their boards too.
one last note...i did clear the CMOS...removed the battery and everything. Also, without a SATA cable plugged in, I can get to the BIOS everytime. Anymore thoughts?
Message edited by quickpaw on 08-23-2007 at 03:35:21 AM
Google Ads
