Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > What graphics card?! New 22inch monitor
Forum Graphic & Displays : Graphics Cards - What graphics card?! New 22inch monitor
Hey, my first post! :hello:
Anyways, not really clued into the latest graphics cards etc. as I'm more of a console person.
I'm buying a 22 inch widescreen monitor (Samsung 226cw) and want to get a new graphics card aswell. I dont really use the PC for gaming, mainly for watching movies, web development and some graphics work aswell. I dont want to fork out a load of cash for a card that I'll only use half of its potential! This is where you guys (hopefully) come in! What would you recommend, need one with a dvi connection. Basically want a good crisp clean graphics display good for movies etc.. Usually used at hight resolution. Any suggestions please let me know.
Cheers guys.
Sponsored Links
8600GT
------------------------------ Q6600@3.4+ TT V1 Cooler,SAPPHIRE HD 4870X2,ASUS MAXIMUS FORMULA,4GB OCZ DDR2 800,LG W2452V 1920x1200
Reply to Maziar
Agreed, the 8600 meets your requirements and is great for movies and the like. You may also want to consider a HD2600xt from ATI as the latest benchmarks have shown that the 2600 and 8600 are about even in most cases, so whichever is cheaper or appeals to you more will probably suit you fine. Note that these aren't great gaming cards but get the job done and since you aren't doing much gaming, they should be fine.
Reply to prodystopian
Cool, yeah that was the one I was looking at :
http://www.komplett.ie/k/ki.aspx?sku=334592
Reply to chris_ie
8600gt or 2600xt would fit your needs. If you are a HD movie buff 2600xt is better for it. 8600gt if you want to game some.
------------------------------ Asus P5B vanilla with E6300 B2 stepping @ 3.5
4 gigs Gskill
8800GTS 756/1836/1037
http://www.tomshardware.com/forum/ [...] ew-benches
Reply to marvelous211
- 0 +
Gigabyte has Both the 8600 and the 2600xt with passive cooling which is nice especially if you want your PC to lean towards the HTPC side of things and keep the noise low.
If not any of them will work just fine.
Reply to pchoi04
- 0 +
Good idea, passive cooling would be a great option for you.
------------------------------ Abit IP35 PRO | Intel E6750 | 4GB Corsair XMS2 800 | 8800GTS 512MB | Silverstone ST75F 750W | Cooler Master 690 | 2.2TB Storage | Dual Monitors | Samsung 226BW |SAMSUNG 906BW | Gamer | Adobe User | Vista Ultimate Sp1 X64
Reply to paq7512
Cheers for all this guys. Its a great help. I'm actually thinking on going for a 24" monitor now, figure I'm gonna pay a bit for 22" so may just go 24"! :P My motherboard doesnt have PCI-E slots. Would it be wise to upgrade the motherboard too or do you think it would be fine?
Reply to chris_ie
- 0 +
whoa, I don't think any 8600 or 2600 will work without pcie, what do you have, agp?
Reply to spuddyt
- 0 +
Please post your full system specs (or as much as you know) so we can provide the best advice for you.
------------------------------ Lian-Li PC-7B | XClio Greatpower 550W | P4 3.2 Prescott SL7E5 | Scythe Ninja
2GB DDR400 Corsair VS (4*512) | eVGA nVidia GF 7600GS AGP vmod 1.46/1.91 OCd 759/907
WD 160GB & 640GB SATA
WinXP MCE 2004
Reply to KyleSTL
Hey, I'll post the specs later. I only really used the PC for movies, web development and some graphics. Going to order the Samsung 226cw, 24" are bit too expensive. Pretty tempted to just do up my PC while I'm at it, get a new motherboard, some extra memory maybe. Although dont want to spend a fortune! Bit pissed off that my board doesnt have PCI-E, it has AGP yeah. Grrrr. Theres bout 1 (maybe 2) gig or ram in it. 1.8Ghz processor. Actually cant believe I cant remember the spec! Ha :P
Reply to chris_ie
Ok.....update. After taking the word of the guy that I bought my PC from (that there was only agp on the motherboard, no PCI-E) I decided to check for myself. What do I find? 2 PCI-E x16, 2 PCI-E x1 and 2 PCI slots! So I can go ahead and order my card now! Woohoo!
Reply to chris_ie
I've just ordered my Samsung 226CW Syncmaster 22" and SAPPHIRE TECHNOLOGY Radeon HD 2600 XT
Reply to chris_ie
There are 737 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
