Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound card issue with vista
Forum CPU & Components : Sound Cards - Sound card issue with vista
I have recently bought some new parts for the inside of my computer. I am still using my old sound card though because its really not that old. It's an Audigy 2 ZS (Creative Sound Blaster). I've tried the new beta drivers to try and fix the problem but i kept getting an error when installing them. The problem I am getting is that the sound and microphone will randomly give out and not work. Sometimes it doesn't even work right when i turn on the computer, but other times it will give out randomly. I think i have the drivers installed even though when i tried to put those in, more errors popped up. The media source and the settings program doesn't work. I'm not sure what to do anymore. Any suggestions?
Thanks
Sponsored Links
What's your OS?
------------------------------ Quando Omni Flunkus Moritati
Reply to GuyAmI
- 0 +
vista home premium 32-bit
Message edited by weston on 08-25-2007 at 05:21:13 PM
Reply to weston
- 0 +
Thanks
Drivers updated from the web will comply with UAA standards. However, due to Microsoft's new Windows Vista™ architecture, some features may be lost. Please refer to the Web Release Notes (WRN) found with the new driver downloads for details.
In addition, the Creative Speaker Settings will not automatically synchronize with Windows Vista™ Speaker Settings.
http://193.95.171.83/SRVS/CGI-BIN/ [...] =obj(9286)
Reply to badge
- 0 +
alright so i downloaded the new drivers for it and media source player. The sound is working now, but like before it took a few hours and it turned off again. The problem i have now is that i have no control over the creative volume control and all the settings. When i try to do diagnostics, it stops at hardware detection and says the only way to fix it is to take the card out and put it back in. Well i did that and it didn't help, i know its in right and the one cord from the sc to the dvd drive is there. I dont understand how i can get the soundblaster settings to work
Reply to weston
- 0 +
I stopped using the Audigys I own in my Vista systems. I'm skipping the Xfi series for my Vista systems. I will wait a while to purchase 24 bit sound cards. I went back to onboard sound using Vista for now.
Reply to badge
- 0 +
yea well, no sound blaster means no subwoofer. the onboard doesnt support it and from what i can hear, it just doesnt sound very good either. so please does anyone else have any suggestions that could help?
Reply to weston
- 0 +
Audigys are terrible with Vista. Onboard is better than an Audigy. Buying an Xfi might work for you, but your Audigy will fall on it's face with Vista.
Reply to badge
- 0 +
Have you tried the KX drivers for vista?
They work great with my sb Live! 5.1... They are compatible with audigy too, so try them.
The version wich i know for sure works with vista is 3538
------------------------------ Desktop: AMD Athlon 4200+ (2,66Ghz), 2GB DDR, Ati Radeon HD3870, Samsung Syncmaster 19" 931bw | Windows 7 build 7600 x64 (RTM)
Notebook: Intel Centrino T8100 (2,1Ghz), 4GB DDR2-667, Ati Radeon Mobility HD3470 | Windows 7 build 7600 x64 (RTM)
Reply to FeareX
- 0 +
where do you get the driver?
Reply to badge
There are 1129 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
