Pick up a 7600 GS or something like that. It's a recent generation card that has relatively low power consumption, decent performance, and won't break the bank. Although....a 7300 would probably even do the trick.
After learning the prices and specifications, I think that most important for a Video card for a bit tomoorow day are DDR3, DirectX 10, anf of course price.
Any of those would be fine for a "non" gamer card. Just a shame that you have a good CPU and Mobo and don't take advantage of it, but it's not mine. If you want Dx10 card, so you can use a 64bit Vista (assuming you would want to), than any of those that you mention would work for that. And if you want to eventually want to play a game later, than you can come back and ask more ?'s if you like. Enjoy your system!
No need for dx10 if you dont game.Nvidia 6 series on up and equivalent Ati cards would do.I would say Nvidia 8500 or Ati 2400 would be fine for what you want to do.
It does not have a fan so that means it is silent. However, it does not have a VGA port (D-Sub) so you'll need a DVI to VGA adapter if your monitor doesn't have a DVI port.
Alternatively, you can go with the GeForce 7300LE for only a little more:
Surfing the net requires no more than a Tesco built rig. Pc world can get u an online ready Pc for far less than buying low end pieces. I agree with previous posters about your mobo + processor. Who told you to buy them for just surfing the net? But its your rig, I know its an english site but
shows you how little you can spend on a card.
For less than £20 ($40) you can get a XFX GeForce 6200 PCI-E64MB - 256MB Turbocache.
about $90 could get you MSI GeForce 7300GS 256MB DDR2 PCI-E
