News
ATI Catalyst drivers have a problem
ATI has a problem in the latest Catalyst drivers. Read more
Quantum effect offers molecular transistors
A molecular switch that operates in a fundamentally new way could usher in a generation of microprocessors that work on the molecular scale. Read more
Robot whiskers sense shapes and textures
Artificial whiskers that mimic the way rats and seals sense their prey might one day let planetary rovers or uncrewed submarines explore the shape and texture of strange objects they encounter on their travels. Read more
Nvidia Contract Makers In Taiwan Low-key Over Defective Chip Reports
Nvidia's Taiwan-based graphics chip contract makers are being low-key after the US chip designer informed investors on July 3 that will take a charge of US$150-$200 million related to expenses stemming from issues discovered with die/packaging materials used in previous generation notebook products. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
System Builder Marathon: $2,500 Enthusiast PC
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
System Builder Marathon: $1,250 Mid-Range PC
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
SSDs Replacing HDDs Soon? Not A Chance
Some say 2010 and even 2009 will be the year of SSDs. We think not. Read more
All the Reviews & Articles
  Tom's Hardware Forums » CPU & Components » CPUs » Strange CPU problem
Strange CPU problem
Word :   Username :
Bottom
Author
 Thread : Strange CPU problem
Profile: newbie
More Information
A few weeks back my motherboard and psu died, which was the start of the problems. I was not sure what the problem was at the time so i took it into a computer repair shop. They replaced the motherboard and psu.
Here is my question...
Since this time my amd 64x2 is not appearing as it used to. In the windows task manager > performance section it is only showing one box under the cpu usage history section. And when i am running a program the cpu is almost always near 100% usuge, where i the past it was considerably lower split between the cores. Also, i am no longer able to assign processes to a specific core.
Any suggestions?
MOBO: WinFast NF4K8MC Empowered by FOXCONN
CPU: AMD Athon 64x2 3800+
Related Product
"Hmmmmmm"
Profile: Honorary Poster
More Information
are you running cpu always intensive programs? Cuz if you are this isn't exactly the most powerful cpu out there. Does only happen when you run programs? Or does it idle with 100% cuz if it does it's a virus called winlogon.exe you'll have to reinstall windows or find anti virus program which i didn't find to fix it. The one box under usage idk wa's going on
Message quoted 1 times
Message edited by itotallybelieveyou on 08-26-2007 at 02:03:10 AM
Profile: newbie
More Information
Not always at 100%
I know its not the best, but the usage has increased considerably b/c it is either only using one core or showing the usage of the two cores combined or something weird... i dont know.
Runs with scissors
Profile: addict
More Information
You say that the motherboard and the PSU were replaced, was the motherboard replaced by exactly the same one? And if not, was Windows re-installed? Another thing to check is the BIOS, maybe dual core support is shut off. Since this behavior started immediately after the hardware change it's really got to be either improperly set up Windows, or BIOS.
Don't go away mad, just go away!
Profile: stranger
More Information
that's is a easy fix. Just goto the Windows Task Manager. select View/CPU history/and select the One Graph Per CPU. And then your problem will be solved.
Profile: addict
More Information
the bios on your new MB may need to be updated for it to be able to use dual core CPUS.
Profile: newbie
More Information
ParadoxMind-
It is already selected.
I believe they did a windows repair but i dont think windows was reinstalled as far as i know. And it was not replaced with the same board > used to be: Motherboard Name: A8AE-LE, HP/Compaq motherboard name: AmberineM-GL6E
How do i check BIOS?
Message edited by bryceray1121 on 08-26-2007 at 04:00:55 AM
Profile: member
More Information
Why not take it back to the repair shop and ask them?
Profile: newbie
More Information
If it comes to that i will, i am just tired of dealing with them. I also can't afford to lose my computer for a week again.
Profile: enthusiast
More Information
Go to the website and read up on BIOS stuff, it should be really clear. That is what recognizes cores etc. If, after the BIOS update you still have problems, format and re-install windows, and put Avast antivirus on it (free) from now on. Sometimes windows gets buggered if components are switched and aren't the exact same (motherboard).
djcoolmasterx - "Ofcourse there is nothing that you are doing that will use that kind of power, beacuse you don't have that kind of powr to do things with."
Profile: newbie
More Information
I accessesed the bios section of my motherboard but could not find anything that had to do with setting the cores.
Any other suggestions besides a windows reinstall (and does this requrie me to reformat my hardrive)?
Monkey wants to steal peaches
Profile: Faithful Poster
More Information
Whilst there is a virus/trojan named winlogon.exe there is also the legitimate winlogon.exe do not confuse the two.
Profile: newbie
More Information
Well i completely reformatted my hard drive as well as reinstalled windows. This failed to fix my cpu problem, it is still only showing one core in the windows task manager and appears to be maxing out much faster than it used to ... b/c only one core appears to be active.
More Information
It looks like you may be facing a worst case scenario, I.E your CPU was damaged when the last motherboard and PSU went phut. :(
Forums are like a herd of performing elephants with diarrhoea -- massive, difficult to
redirect, awe-inspiring, entertaining, and a source of mind-boggling amounts of excrement
when you least expect it.
More Information
I believe that on that board you need a BIOS dated 5/19/2005 or later to correctly identify your X2 processor. Check your BIOS revision date, could be you just need to update it.
Nuke it, Nuke it good!
Profile: Eternal Poster
More Information
Any suggestions?
Did nforce boards not need a bios update for dual core. and from the looks of things i can not even find that board on either leadtek's or foxconn's site. Looks like they gave you a board that just will not run dual core(so you have 1 full cpu disabled). I could be wrong but I can find NO reference to anyone running that board with ANY x2 cpu in it. Go back to where you got it fixed and tell them you want a board that supports dual or a bios to make it work....
Just some things to look at...what does the bios call the cpu...what does windows call it? check CPU-Z as well
If you have the time and a spare drive you can try to re-install, but it looks like a board issue to me
Message edited by nukemaster on 09-09-2007 at 07:13:26 PM
http://img145.imageshack.us/img145/4269/inukexz9.png
http://tinyurl.com/26uxxb - Core2 Temp Guide? http://tinyurl.com/cj3pw - VGA power use?
http://tinyurl.com/5v55wk - Core2 Memory performance? http://tinyurl.com/6pmbke - SLI/Xfire?
