News
Intel blocks Nvidia from running SLI on Conroe platforms?
The Inquirer reports that Intel may not be supporting SLI on its Conroe motherboards. Read more
Intel: Desktop dual-core processor "Conroe" due in 2006
Intel provided a few more code-names of future processors during a briefing with financial analysts in New York. Read more
IDF Taiwan: Intel confirms packages for Conroe and Woodcrest, but remains fuzzy on Merom
At IDF Taiwan, Intel officially confirmed packaging for two of its first 65nm dual-core processors (Conroe and Woodcrest) based on the next-generation Intel Core microarchitecture, but failed to clarify packaging on a third processor (Merom) using Intel Core. Read more
Intel reschedules launch of Conroe and 965-chipset to July 2006
Intel will push up the launch of its desktop Conroe CPU and delay the debut of its 965-series chipset so that both will hit the market at the same time in July 2006 in a demand-boosting strategy, according to sources at motherboard makers in Taiwan. Read more
Latest Reviews & Articles
Value In SLI? GTX 260 Core 216 Vs. GTX 280
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
System Builder Marathon: Performance & Value
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
System Builder Marathon: $2,500 Enthusiast PC
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
System Builder Marathon: $1,250 Mid-Range PC
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
All the Reviews & Articles
  Tom's Hardware Forums » Overclocking » CPUs » Conroe 2160 , OC Problems !
Word :   Username :
Bottom
Author
 Thread : Conroe 2160 , OC Problems !
Profile: stranger
More Information
Hi everyone ,
i've been using my Cpu @ 2.7 Ghz for a time @ 1.437Vcore , and wanted to go higher but then realized that for a boost of 300 Mghz , i have to increase the Vcore to 1.60v . is that normal ? ( Idle Temp : 30 , Full Load : 51 )
i read in Other forums , that many have been able to Overclock 2160 to 3.4 Ghz and even higher with less Vcore ...
http://www.benchmark.co.yu/forum/a [...] 1-p-3.html
( i couldn't undersand the language but it was clear enough ... :D )
MoBo: Asus P5K
CPU: E2160@3056MHz@1.400v(BIOS)
MEMORY: 1GB DDR2 800MHz OCZ Gold Edition XTC@917MHz(4-4-4-12)
COOLER: Gemin II ( 2X120mm fan )
Cooler Master Premium Thermal Compound Kit
Ima vdrop sa IDLE 1.376V na 1.320V u LOAD rezimu.
Temp. IDLE =37
Temp. LOAD=65 and also
E2160 @ 3200MHz @ 1.375V
MoBo: GIGABYTE P31-DS3L @ FSB-356MHz (moze i 400x8)
CPU: E2160 @ 3200MHz @ 1.375V (u Biosu setovano na AUTO)
Memory: 2x1GB KINGMAX DDR2-800 @ 854MHz
Ima vdrop sa 1.375V u IDLE na 1.344V u LOAD rezimu.
vDrop koliko sam video po netu od 0.025V je sasvim normalna pojava pri LOAD-u.
Temperature @ BOX cooleru su:
Core temp (Tjunction)IDLE/LOAD: 43°C/80°C
CPUcase temp (Tcase)IDLE/LOAD: 33°C/68°C .
wanted to know , if there is any other thing that i should do , except increasing Vcore and FSB , when overclocking 2160 so that i might get a result like those posted on many websites ...
Thanks !
Ps : i'm using Asus P5k , Intel 2160 + CoolerMaster Eclipse , 2 * 1 Gb Crucial Ballistix Tracer
Related Product
Profile: Forum Veteran
More Information
First thing to know is you can't get the exact same o/c with the exact same settings from someone else. Every part is different. Even 2 e2160's are different. In a nutshell, you can't copy other settings & expect the same result.
The P5K has a bit more settings than some other P35 boards like Gigabyte's. It's a bit more complicated.
Have you read the o/c sticky here? When you up the FSB & it becomes unstable, you up the NB/MCH voltage by a notch. Don't go over 1.5v vcore on air.
Profile: newbie
More Information
how far can u overclock on stock voltage??
Beyond the walls of intelligence, life is defined.
Google Ads
