Solved
A940 print problems. Color will not print and black text is poor and incomplete.
My XP recently became corrupt and I had a local computer repair shop reinstall a new version. After I reinstalled the driver software for the Dell A940 printer I discovered it would not print color at all and the black was weak and incomplete. The printer worked fine before.
2 answers Last reply Best Answer
More about a940 print problems color print black text poor incomplete
  1. Best answer
    Go to device manager! uninstall the printer!
    Clean the printer drivers using Driver Cleaner pro 1.5
    http://downloads.guru3d.com/download.php?det=745
    Unplug the printer form your computer & restart!
    Plug in your printer!
    Re install the Printer drivers ant try!
    Also check for any other missed device drivers!
  2. Best answer selected by krayrob.
Computers Printers Windows XP
