Quirky Wireless Connection
Forum Wireless Networking : Setup, Configuration & Security - Quirky Wireless Connection
Hi. I have set up a wireless G router to my cable internet and installed a wireless adapter on my desktop computer. I was initially able to get on some websites and not others and then miraculously one day I was able to get on all the websites I tried. Then just recently it went back to the same problem with limited website viewing and sometimes the internet page will freeze when I attempt to go to a "non preferred" website :wahoo: Anyway, the signal shows connected and signal strength excellent. Any advice that you can provide would be greatly appreciated. Thanks.
~Debbie
Sponsored Links
~Debbie
Are you having this same issue when you disable the wireless and go on the wire?
------------------------------ CCNA, CWNA, CQS-CWLANSS
Reply to gstefanick
No, when I disable the wireless and go on the wire, everything works fine. It seems to be a problem that comes and goes too. Thanks.
~Debbie
Reply to debbielc21
- 0 +
seems a touch random, have you tried uninstalling and reinstalling the card?
Reply to montyuk
I haven't as it's currently working but if it drops again, I will try that. Thanks for the advice.
~Debbie
Reply to debbielc21
Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > Quirky Wireless Connection
There are 1129 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
