Ok, so I just finished a build, started up the newborn bundle of power and all is well.. except that is, when I began to install the OS something odd was noticed. I installed Windows XP Pro SP2. On the blue screen at the beginning of the process when you format and all that jazz, I was creating a new partition since the HDD is a brand new one. The HD is a Western Digital Caviar SE 16MB 250GB SATA. What I noticed while creating the partition was that the Hard Drive is only being detected as having 137GB of total available space... I partitioned the drive and installed Windows without any problems at all and when I go to My Computer and hover the cursor over the C: it still says 137 total space.. ??!?!? I double checked to make sure the cables are properly connected and they are so I am lost, is it just a bad drive? or is it something I'm doing or not doing?? Any help is greatly appreciated.
The system specs are as follows:
ASUS M2N32 SLI - Deluxe WIFI Edition
AMD ATHLON64 X2 5600 + (2.8GHZ)
2GB Kingston RAM
eVGA Geforce 8600GT (256MB) PCI-E
Western Digital Caviar SE 16mb 250GB SATA 2 3gb/s
etc.
As I said before, everything else seems to be working and being detected perfectly...!?
Thanks in advance!
-Jagnet
2GB Kingston RAM
etc.
Thanks in advance!
-Jagnet
