Hello all,
I have an HP 760n from about 5 years ago. Over the years I've upgraded the system (RAM from 512 to 768, and just recently to 1 GB) and video card from a 32MB TNT2 N64 to a 9600 XT.
Recently I decided it was time to try and upgrade the CPU, popped it in, turned it on, and nothing happened. The system powered on, but not even the BIOS showed up.
I popped my old CPU back in, and the system works fine.
I'm wondering whether it is because the board is incompatible with the CPU, or if its because the CPU was defective.
Original CPU - Willamette P4 1.8/256/400
New CPU - Northwood Celeron 2.5/128/400
Mobo - Asus P4B266-LA - It states explicitly that it supports Northwood cores.
I'm also wondering if it's possible to use a 533 FSB CPU with it, since the latest news I found about the mobo stats that it supports up to 100 MHz quadpumped = 400MHz.
Thanks for any help.
