Hi guys,
Just got a new pc about a month ago and im looking at overclocking it. I've never overclocked anything before but ive been reading lots of guides on the net and i think i need a better heatsink.
My specs are:
Q6600 2.4GHz (go stepping)
8800gts 320MB twintech
2x 1GB Kingston ram 800MHz
gigabyte GA-P35-DS3P (rev 1.1) fsb 1333
Antec P182 case (with all 5 fans installed)
550W antec NEO PSU
Everything is still using stock cooling and the extra fans in the case are just cheap brands. I just bought Vista home premium and im still waiting for the 64bit dvd to arrive so im still running XP.
My goal for it is to have faster render times in 3ds max and higher framerates in games (especially crysis).
- I'm willing to spend $120 (aud) on a new heatsink and fan for the cpu. What would you guys recommend i get?
- I'm thinking that taking it to 3.0 or 3.2 will be sufficient. Are these safe numbers when only using aircooling? If i do this will any of my other components bottleneck the performance?
- The thermalpaste stuff is included with the heatsink right? if not can you recommend me one?
- Do you know any good guides (for beginners) for installing heatsinks?
- Is there anything ive forgotten or overlooked?
I really want to stay at safe numbers because theres no way i can afford to replace anything.
Cheers
P.S. im in Australia (hot climate )
My specs are:
550W antec NEO PSU
Cheers
