I have a motherboard IB9. It no work with my components.
The motherboard found with a Core Duo 3.0, 532mb kinston 533 and gigabyte 1950 pro.
But it doen't work with my components, core 2 duo 6600, pny 667 1gb and gigabyte 1950 pro. Press de start buton, I heard a Beep and I can't see nothing in my monitor
Every this components work in other motherboard -Asrock dual 775- but doen't work in my IB9
In the computer shop does't back the money becouse the motherboard is OK.
I need help, I was three moths try solve this problem
The cpu was PENTIUM D PROCESOR 935 2X3000 GHZ. With this cpu and the memory kingston systen found. That told me the tecnical suport where I bought the Abit IB9.
Quote :
That motherboard is a Intel 965 chipset, it should work fine with what you have. So you not getting any video? Have you tried re-seating the video card? Is the power cable from the power supply plugged into the video card?
I dont have more video cards pci-e for test, but my vga is ok, it found in others system.
of course I conect the power suply in my vga.
When I press the start button, I head a beeb large and 2 beeb short. This mean that my vga dont found good. isn't it?. But my vga is ok and found with a pentium 935 processor.
Too, the system start good random. But y dont install windows because the system interrup it and the systen no found when I reset it.
My power suply is a 480W Tascen.
Message edited by Faldo27 on 09-12-2007 at 11:33:11 PM
