Tom's Hardware > Forum > CPU & Components > CPUs > Problems installing heatsink for Q6600
Forum CPU & Components : CPUs - Problems installing heatsink for Q6600
Ok, I installed the CPU, now I'm putting in the heatsink that came with the Q6600 CPU. I place it over the CPU and it's one of those where you just push the pins in to install (rotate and pull them to remove). It won't go in. I push in one side, and when I do the opposite corner, the other pin pops out. Anyone ever have problems doing this?
Also, should there be a greyish residue on the cpu and bottom of the heatsink after I pull it out?
This is my first time installing a CPU, so any help will be greatly appreciated.
Sponsored Links
If you are trying to install it in the case then remove the mobo and install the HS outside the case, it will be easier in the long run. Later you might invest in the Thermalright Ultra 120 Extreme with a Scythe S-FLEX SFF21F fan. Installation of this will also require removing the mobo. The Q6600 will benefit from the additional cooling especially if you overclock it. The grayish residue it the thermal compound leave it on there unless you have another tube of it lying around.
Message edited by Zorg on 08-31-2007 at 10:21:12 PM
Reply to Zorg
- 0 +
Easy to say spend more money but you should get a new heatsink, there are lots for $30-$40 that will make a HUGE difference. The one taht comes with the Q6600 is garbage.
Reply to fred-e
There are 1063 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
