Hello everyone,
I have a quick question.. I have a wireless network that I use at home. But my brother's and dad's computer dont seem to be getting a very good signal. I live in an apartment with concrete walls.
The Router is the D-link DI-724GU.
I am not sure which would work better for me. I was thinking of either getting an access point and use it as an extender like the D-link DWL-2100AP place it in an area between the 2 computers or replace the Antenna's on the Router I have with more powerful ones. The stock ones I believe are 3dBi signal. I was thinking of replacing them with the Dlink ANT24-0700, which have 7dBi signal.
Which do you guys think would help more?
Thanks
Message edited by primal_groove on 01-17-2009 at 04:08:33 AM
is it possible to place the router in a more central location between all 3 machines? test moving the router around (doesnt need to be connected to the net) and see where ideally it would be positioned to get the best signal for all 3 machines, once you've found this position see what you would need to do to get it connected to the net.
Thanks for the reply. I thought about that but I would like to keep the router where it is as that space is my "trouble shooting" and repair location when someone gives me their computer to fix/repair. So I just plug a short Cat5 cable in there.
thats why I thought about either the AP or the Antenna.
