When i play any games (even when i played it with my 7900GTX ) i had a periodic 1 second graphic lag , i dont mean my games lag , no , i mean for example when i played MOH:AIRBORNE , well the game runs very good , but for example when i am dropping off from plane or i am walking , i have many lags which only last 1 second(as i said , PERIODIC 1 second lag ) , what is the problem ?
i had this problem with my 7900GTX as i said , also i had 163.44 driver for VGA ,so i thought it was for the Driver, so i uninstalled it and installed 162.18 , but still the same ( i am using xp 64)
------------------------------Q6600@3.4+ TT V1 Cooler,SAPPHIRE HD 4870X2,ASUS MAXIMUS FORMULA,4GB OCZ DDR2 800,LG W2452V 1920x1200
Ummmm... your question is unclear and could result from many problems.
1. The game you are playing is loading something to your vid card memory, computer memory, or from Hard Drive and it is slow.
2. Your processor is pausing to save the game.
3. You don't have enough power to power the parts.
4. Your parts are over heating or unstable.
From looking at your system spec, it should be fine in terms of requirements, so my guess is #4? If you can clarify the problem, is it any game, just MoH:Air, computer temperature / specs?
for one thing some games load in real time(most mmo's do this and such lag is not a problem, in a FPS the map should be fully loaded before play, but who knows) so there may be a lag when it loads the next section of the game into your video ram.
You could also be running out of ram and your computer is paging.
You could have a process out in windows that is stealing priority for a second now and then.
Your virus scanner can also be scanning parts(files) of the game as they load(real time protection)
With your system specs its kind of surprising...
Message edited by nukemaster on 09-14-2007 at 10:47:47 PM
well thanx for all replies, as i said in MOH:AIR BORNE ,when i am dropping off from the plane , i have some of those lags , so this could be that its loading right ?
Open the nVidia control panel, go to "Advanced 3D Settings," and set "Threaded Optimization" to "Off." I had the exact same problems you're discussing, and this fixed it for me.
i will do and will see what happens ?
also isnt it because i have an old LCD? (i myself dont think so , but it maybe , because its 5 years old)
Message edited by Maziar on 09-15-2007 at 08:59:41 AM
Reply to Maziar
well it is fixed , i turned off THREAED OPTIMIZATION and everything is very good now , and now i have some STOPS in normal situations like Check points or when the map changes but they dont affect my gaming
Reply to Maziar
well , they are back , and i dont know what to do , i was recently looking @ MOA :AIRBORNE extra features and there was a scene in it about jumping out the plane and that video had the same issue too , so could it be the games problem ? well to be honest this 1 second lags dont hurt my gaming , but i wanted to know the reason of it
Reply to Maziar
As soon as i read what you said about jumping out of the plane i remembered the demo videos...its the game(i saw it in the video too). Thats is a massive area to render and i am sure it loads higher rez textures as you fall.....
Using XP 64 too on my PC (GTS 320, NeoHE 500, E6400, 2 Gigs of ram) and I experience no problems on MoH: Airborne. (Some FPS drops into the 30-40s but the motion blur effect is so good that I dont care )
I have an old screen too, 17" Samsung SyncMaster 793s CRT (3 years old since I bought it), but one thing you might be right? I'm using 163.67 drivers (beta released 3 or 4 days ago) and X64 SP2.
i had 163.44 then i deleted it and installed 162.18 , i will download 163.67 now and will post the results , also i will get SP2 soon and will post the results ,
thanx
Reply to Maziar
bad news guys , i installed 163.67 and its still the same , tomorrow i am going to install SP2 and will see what happens, by the way should i set THREADED OPTIMIZATION to AUTO again or let it be OFF ?
btw i tried it on VISTA(ultimate) 32 too , still the same
Message edited by Maziar on 09-15-2007 at 07:55:35 PM
Reply to Maziar
well i have bought a 8800GTX to max out everything , but its ok about post processong , i will set it to simple and also i will try OFF and will tell u what will happen
Reply to Maziar
If you're having the problem when playing online I would consider punkbuster as a possible cause. Their newest software is a piece of crap* causing all kinds of problems. I believe it was automatically installed with a lot of games in August. You will see one or some processes running like pnkbstrA, pnkbstrB. PnkbstrA gets automatically added to you're startup and will be present when you are not gaming. Admittedly it seems to do nothing but when you are gaming it loads pnkbstrB which will keep you're hard drive busy the whole time you game. If you have ever tried to do a virus scan or defrag while gaming you would recognize the kind of lag this produces.
*I don't take calling some one's software a piece of crap lightly but feel it is warranted.
OMG.....forgot about PB......has caused HELL in wolf ET...seems ok for ETQW....
Either way i am playing the game...but that post processing pissed me off to no end....as does having to exit the game to change settings....
I have not noticed those 1 second lags but fps getting into the 40s(jumping out of the plane) kind of sucks....I am extremely sensative to fps drops of 60-50....but if it ran 30 solid(GTA with frame limmiter) i would barly notice...its seems to be the drops that are noticable not the fps itself...
well i installed it , its SP1 but i can update DX9 now which i couldnt with the last one , and now i am installing MOH:AIRBONRE and will tell you what happened
Reply to Maziar
@maziar: oh right...i forgot about the filtering. They have in Saudi Arabia aswell. Any site which isnt filtered? Or i'll just upload it somewhere and give you a direct link to download it if i can.
@Nuke: Yeah i finished that recently. Havnt had a go at the next round just yet. Been busy finishing off bioshock lol! finished it yesterday.
to blade , thanx for your link , well mine is somehow better than yours ,u have those little lags too , but i think u dont notice them , u see when u drop from the plane then look @ the ground , u will see very little lags , but you lags are few like mine
Reply to Maziar
