I was told (or at least I got the impression) that your ram needs to be running at the same speed as your front side bus, or you will run into a bottle neck. I'm looking into a Q6600, and intend to up the FSB to around 400 mhz (which, I believe, = 1600mhz bus and 3.2ghz clock?). Anyhow, does the ram need to be running at 1600mhz to avoid a bottle neck, or is it 800, or 400, or what? Given that it is double data rate, I'm assuming it needs to run at 800mhz for this bus speed but, again, I'm not sure.
