Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Slave hardrive formating problems
Forum Homebuilt Systems : General Homebuilt - Slave hardrive formating problems
I have bough and connected my new hardrive as slave. I use windows xp manually to format and so on but ti disappears form the drive list with in 24hours of it working. I used segate disk wizard to format it didn't help neither it also disappears from the list and re aperas asking to be formated again. How do i fix this problem.
Sponsored Links
Try going to Control Panel - Administrative Tools - Computer Management - Storage - Disk Management. Format it there but do a quick one cause it will take way too long to format completely. Try this first see if it works.
Reply to CmdPT
thats the problem i already did that but it disappears after couple days and asks to format again and sometimes it says error
Reply to ant101
System and drive spec etc?
Reply to gent
First of what kind of hardrive is it SATA or IDE drive?
Reply to CmdPT
Its an IDE 320gb
Reply to ant101
The you should try pushing the IDE cable again and also the power cable that plugs into the HD maybe its just loose. This happened to me so many times on my other PC.
Reply to CmdPT
If your mainboard has a VIA chipset, that could be the cause too. If nothing helps, update the bios and let the bios do the plug and play configuration. That usually helps.
Reply to Slobogob
Download and run manufacturers diagnostic, see if it passes.
Mike.
Reply to mike99
Why would that cause it?
Reply to ant101
How do you upgrade the bios and will this delete my current version that i am running on my master?
Reply to ant101
There are 879 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
