Ok i have done my research on everything except for cooling and cases!
So first off, i have a budget for cooling, $150 - $200
Second off, i would like suggestions for a good case with nice airflow design thats cheap enough to where i can buy more cooling.
Third off, any cheap, quality liquid cooling? If not should i go with the Blue Orb 2 or the Zalman CNPS9700 LED 110mm 2 Ball CPU Cooler? Or a better fan?
And finally, im going for a 3870x2 (whenever it comes out) and i was wondering what i should do with its cooling? Replace the fans with better ones that are quieter? or keep the old one?
