I just overCLocked my amd 6000+ from 3.0ghz to 3.3ghz.. Im using 1.55v for cpu and 2.4v for ddr2 RAM my bus speed is 220. In my bios it says that im running at 3.3ghz... but on cpu-z it says my bus speed it 200 and my clock speed is 3.0ghz....WTF!! THAT DOES NOT MAKE ANY SENSE!!!
CAN ANYONE PLEASE HELP ME IM REALLY LOST!!!
AMD X2 6000+ @3.2Ghz | Asus crosshair | 4gb corsair xms ddr2 800 | BFG 8800GTS (g92)x2 SLI 805/1080 | SoundMax HD | (160gb)x2 sata in raid 0 | 500 gb sata | Lian-Li PC-6070 | antec 850W PSU | thermaltake water cooling | Vista 64bit | LG 24" | Logitech 5.1
CPU-Z tells the truth. Your processor is probably overheating or is not able to run at the specified speed, and the motherboard is setting it to the defaults without warning you. Try setting your bus speed to 201, without voltage adjustments of any sort and reply back us your frequency measured in CPU-Z.
im at work right now so i cant run home and check on anything on my computer...but the idle temps that i was getting were normal...around 40 to 45C...it just dosent make any sense. Unless my voltage was set too high...I set it to 1.55 or 1.6 to start and i forget if I changed it.
