Try powering the printer off\on to reset it and make sure there are no errors showing (ie, Out of paper, Out of ink), also check that the cable is plugged into both the printer and system. Windows will queue the documents and keep them there until the printer is ready to print them so if they are still waiting there is some reason the system thinks the printer is busy or offline.
