Ahoy, folks. I'm having trouble with a computer I've recently built. With all the oodles of games coming out soon, I figured it was about time to upgrade the old thing. I've got:
Case: CoolerMaster "Wavemaster"
http://www.pcstats.com/articleview.c...id=1552&page=6
Processor: Intel Core 2 Quad Q6600 2.4 Ghz
http://www.newegg.com/Product/Produc...82E16819115017
Motherboard: Gigabyte Intel P965 LGA775
http://www.newegg.com/Product/Produc...82E16813128042
RAM: 2GB (2x1GB) Kingston DDR2800
http://www.newegg.com/Product/Produc...Tpk=KVR800D2K2
Power Supply: Silvertone ST75F
http://www.newegg.com/Product/Produc...6009&Tpk=st75f
Graphics Card: GeForce 8800GTS 320MB
http://www.newegg.com/Product/Produc...Tpk=PVT80GGHD4
I've also grabbed 2 hard drives (one 320GB and one 500GB) in addition to my two old hard drives (two 160GB drives).
All of the above parts have already been bought and purchased. Anyway, here's the problem. I assembled the whole rig together, but when I turned it on, nothing happened. We tried several things, including testing with a volt meter, only to conclude that we weren't getting proper voltages in the cables, and sent it back and got a replacement. When the replacement finally came, I plugged it in, hooked up the new hard drives, got everything up--AND IT WORKED! However, since the hard drives were blank, there was no Operating System on it, so I had to turn it off and plug in the old drives. When I pressed Power--boom, nothing happened. No case fans, no nothing.
This is the second power supply that's blown out on me, and I'm rather ticked. I've talked to a friend, and he says that I wasn't getting enough amps under the 12v. The side of the power supply reads as follows:
MODEL NO: SST-ST75F
750 WATT POWER SUPPLY W/PFC
AC INPUT: 115 - 240Vac , 60 - 50Hz , 10 - 5
OUTPUT: +3.3V +5V +12V1 +12V2 +12V3 +12V4 -12V +5Vsb
MAX(A) : 24A 30A 18A 18A 18A 18A 0.5A 3A
According to my friend, I should be getting 24V under 12V, not 18V under 12V. Anyway, I'm thinking of getting an entirely new PSU, as I'm rather fed up with the whole business. Any thoughts?
MODEL NO: SST-ST75F
