Hi everybody, I hope some of you can help me with my situation. There's a lot of good knowledge and help on these forums and I would appreciate your time.
I have just completed a new build a couple of weeks ago consisting of the following...
Case - Antec 900
PSU - Q tec 500W (from my old PC - see http://www.qtec.info/products/product.htm?artnr=13981)
Mobo - Gigabyte GA-P35C-DS3R
CPU - Intel E6750
RAM - 2x1GB OCZ Reaper DDR2 at 1,033Mhz
Graphics - EVGA stock 8800GTS (320MB)
Hard Drives - 250 and 500GB Seagate Barracudas
Optical Drivers - Pioneer DVR 112
The build was fine and my computer ran perfectly. Today I took out the PSU to tidy up the wiring, and upon completion of this after plugging everything back in, I turned on the power and nothing happened except a small fizzling sound from the PSU. This sound didn't happen again unless I pulled the power cable out of the PSU and then put in back in and tried to boot.
I attempted to take out the power cables from unneccessary peripherals (to check if the wattage draw was larger than the output of the PSU), checking the internals of the PSU for any burning smells or visible damage (after taking out some of the standing voltage by placing a screwdriver each of the plug pins), and trying to just turn on the PSU with no cable attached to my computer to see if it would start and the fan would turn.
I have no idea why all of a sudden it is not working. I'm also quite worried that maybe something has happened in relation to a power surge and damaging my new components. Has anybody come across this problem before, or got any ideas as to what else I could try?
Thanks,
Mike
Case - Antec 900
CPU - Intel E6750
Thanks,
Mike
