Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » independant VGA power supply question.
Add a reply
 Word :   Username :
Bottom
Author
 Thread : independant VGA power supply question.
Profile: journeyman
More Information
I want a 2900XT in the next few months when I up/downgrade to Vista.. I also want the ability to crossfire without having to up the power supply since I've got my wires all fancy.. I'm assuming the 430w Thermaltake TR2 (URL below) will just die.. I know that the PCI-E X16 slot gives at least 50 watts of power so I am wondering which 5.25 inch bay PSU would give me the sufficient power for the future of Crossfireing DX10.. I don't plan on upgrading the mobo/cpu for nearly 2 more years..
(AND is it possible to even use a 2900XT without an additional power supply? whether i have to take out a few fans, disable a hard drive, etc..)
My PSU gives good rails like 11.95 on the +12v, 3.25v on the +3.3v and 5.03v on the +5.0v and if I did get the independant PSU I could see those rails stabilizing to almost perfect.. (it would no longer have to power the Video Card)
====setup====
Opteron 165 @ 2.9ghz w/ 1.4v
Asus A8R32-MVP Deluxe
2GB Patriot DDR400 2.0-2-2-5-1T
X850XT
SB Audigy 2 Platinum
1 SATA CD/DVD Burner
1 80GB HD
1 120GB HD
3 120mm fans
3 80mm fans
1 80mm slot cooler
[if any of you can tell me the amount of power i am using (omiting the X850XT) that would help me out a lot.. I just don't know how to estimate the usage..]
[/url]http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023[url]
Related Pr oduct
Why so SeRiOuS?
Profile: old hand
More Information
This is a link that someone else posted yesterday in another thread. Check this out and it should give you a ball park idea...
http://www.extreme.outervision.com [...] orlite.jsp
Be careful and read what you select very closely. I made mistakes the 1st time I used it so watch out...
Message edited by englandr75 3 on 09-07-2007 at 08:00:58 AM
Profile: Ancient Poster
More Information
your way off
you need a 850 singel rail or 1000w multi rail for 2x hd2900's and room for a hot quad and many drives!
Why so SeRiOuS?
Profile: old hand
More Information
dragonsprayer wrote :
your way off
Actually, 90% of the peeps in here will tell u that you don't need that much power even for these specs. Do you think the 2900s use that much more power than the 8800GTX cards? They honestly shouldn't.
Use the calculator on my previous post and it will give you a close estimate on what you need. If it makes you feel more comfortable go a little higher than the calculator recommends. I personally would feel better doing the same but you will have to shop carefully for a decent quality PSU if you are trying to keep the cost to a minimum.
Add a reply
Google Ads
News
Read Your Watts With A GPS Technology Power Supply
Published on June 04, 2008
Taipei (Taiwan) - While walking the halls of the Computex trade show, we saw this interesting power supply with an integrated watt meter. Read more
Tiny power supply cranks out 120 watts
Published on January 27, 2006
For some users, computer designs can't be small and quiet enough. Mini-box.com has begun offering what it claims to be the world's smallest ATX compliant power supply that uses a single 12 volt power source and puts out 120 watts. Read more
CeBIT 2008: Thermaltake Offers 2kW PSU
Published on March 09, 2008
Thermaltake now offers a high performance power supply for users that just can't get enough power. The new model belonging to the Toughpower line provides up to 2 Kilowatts of power. Live demonstrations are given at the company's CeBIT stand Read more
OCZ rolls out 600 watt modular power supply
Published on October 09, 2006
OCZ Technology Group has introduced a new modular power supply with a sustained output of 600 watts. The PSU will hopefully lessen cable clutter because only the necessary power cables need to be attached. The titanium mirrored case comes with two PCI-Express cables and a 4/8 pin CPU auxiliary fan connector. Read more
Latest Reviews & Articles
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
Stalker: Clear Sky - Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
