E6750 @ 3.760 65C under load - safe temps?
I managed to OC my e6750 to 3.760(470x8) 1.4v vcore in bios(1.36v in cpu-z), and some fsb and mch tweaking. I'm getting temperatures of 50C under load in speadfan 4.33, so i'm assuming it's really 65C, is this a safe temp to run 24/7?
1 answer Last reply
More about e6750 load safe temps
  1. gamer101, the following scale applies to your processor's CPU (Tcase) temperature and Core (Tjunction) temperatures, which is according to Intel's specifications, and is shown in the Core 2 Quad and Duo Temperature Guide: http://www.tomshardware.com/forum/221745-29-core-quad-temperature-guide
    Section 6: Scale
    Scale 1: Duo
    E6x50: Tcase Max 72c, G0 Stepping, Tjunction Max 100c, Vcore Default 1.350, TDP 65w, Delta 10c
    -Tcase/Tjunction-
    --70--/--80--80-- Hot
    --65--/--75--75-- Warm
    --60--/--70--70-- Safe
    --25--/--35--35-- Cool
    You can use Section 9 to Calibrate your temperatures, so that you're sure they're correct.
    Comp :sol:
CPUs BIOS Overclocking
