Looking for some advice concerning cooling.
Setup; No OC
QX6850@3.0Ghz
Asus P5K-Deluxe
Artic Square Cooler
4GB Ballastic Tracer @ PC-8500
Apevia X-Infinity Case
Fans 3-80mm intake 2 front and 1 side. 2 exhaust fans 1-120mm rear and 1-80mm top. Along with power supply which has 2-80mm.
Using Everest Ultimate and SpeedFan 4.34 Beta 34 my temps at idle are;
CPU=45c
CPU 0=55c
CPU 1=54c
CPU 2=54c
CPU 3=51c
Within 3 minutes of starting a system load test using Everest System Stability test the CPU jumps to 65c and all Cores show low to mid 70c's
Is this rapid temperature increase due to restricted airflow in the case or the cooler or a combination of both?
I have checked and reseated the CPU Cooler with Artic Silver 5 as per the instructions on their web site for quad core cpu's. No change in temps.
I would like to OC to at least 3.4 and have tried but the temps shoot up to the mid 80c's.
Any suggestions to correct this would be deeply appreciated.
Setup; No OC
QX6850@3.0Ghz
Asus P5K-Deluxe
Artic Square Cooler
CPU=45c
CPU 0=55c
CPU 1=54c
CPU 2=54c
CPU 3=51c
