Closed Solved
Help with Skype, cencel the echo!
So in my ideal setup I would have a desktop mic and be able to play my game at a decent volume. Currently my friends say they can hear the game echo through my mic, so I switched back to my headset. I have a decent sized desk and put the mic far away from the speakers but no luck. Also I didn't find any sensitivity settings in Skype. The only thing I found was to take it off auto and set the bar manually but then everyone said my voice was really quiet. Is it possible to achieve this ideal setup or should I stick with the headset?
4 answers Last reply Best Answer
More about help skype cencel echo
Multimedia Gaming Headsets Games Skype Apps
