Relative power consumption
I know its a kind of weird question but i have a rig that has the same ATX 400watt psu as a friend now the one i have is running a x1650xt and he asked me what sort of power its using,well i dont know but he wants to upgrade his graphics from a x800 series card and asked me the question to try and work out if he could run a 1950GT on his.
So the question is how much differance is there between the two cardspower wise ?
Yes i know its not the most scientific /best way about it but i said i would try to find out so here i am :)
Mactronix
7 answers Last reply
More about relative power consumption
  1. what are the amp readings on it? and what make is it??
    im pretty sure the 1950Gt is a fair bit more power hungry than what u have.
  2. Just look up the power usage of the card when lookin for a review, a lot of the time, better sites will give you the wattage the card uses in the system...
    Mactronix
    X1650XT= 55w
    X1900GT= 75w
    no info on 1950GT
  4. http://www.xbitlabs.com/articles/video/display/radeon-x1650xt_4.html
    The X1650XT you have uses quite a bit of power too. Figure about 10 watts more for the X1950GT. You are better off having 30amps on the 12V rail for both those cards.
  5. Thanks for the links guys it seems that there is not that much in it even if the numbers on the charts are wildly differant they say that the cards are similar. however looking at the cards on the charts i am going to recomend he dosent risk it and gets him self a 7950 less power and more performance.
    Thanks again
    Mactronix :)
Graphics Cards Power Consumption Graphics
