News
Tiny power supply cranks out 120 watts
Published on January 27, 2006
For some users, computer designs can't be small and quiet enough. Mini-box.com has begun offering what it claims to be the world's smallest ATX compliant power supply that uses a single 12 volt power source and puts out 120 watts. Read more
CeBIT 2008: Thermaltake Offers 2kW PSU
Published on March 09, 2008
Thermaltake now offers a high performance power supply for users that just can't get enough power. The new model belonging to the Toughpower line provides up to 2 Kilowatts of power. Live demonstrations are given at the company's CeBIT stand Read more
OCZ rolls out 600 watt modular power supply
Published on October 09, 2006
OCZ Technology Group has introduced a new modular power supply with a sustained output of 600 watts. The PSU will hopefully lessen cable clutter because only the necessary power cables need to be attached. The titanium mirrored case comes with two PCI-Express cables and a 4/8 pin CPU auxiliary fan connector. Read more
Thermaltake PC Hardware Gets Nvidia ESA Certification
Published on February 15, 2008
Thermaltake announced recently that three new products in its PC case, power supply and cooling system lineups have recently received Nvidia ESA (enthusiast system architecture) hardware platform certification from Nvidia. Read more
Latest Reviews & Articles
AMD Phenom II X4: 45nm Benchmarked
Published on January 07, 2009
Can AMD finally recapture its former market lead with the Phenom II? We tested their new 45-nm CPU, which is compatible with AM2 motherboards. How do things look from performance, energy consumption and overclocking perspectives? Read more
Best Graphics Cards For The Money: Jan. '09
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Scorpio Blue: Big Notebook HDDs Go Mainstream
Published on January 06, 2009
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
Value In SLI? GTX 260 Core 216 Vs. GTX 280
Published on January 05, 2009
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
Power Supply Suprise
Word :   Username :
Bottom
Author
 Thread : Power Supply Suprise
Profile: journeyman
More Information
Im looking to buy a power supply for my new system build. Just to give you an idea. I will be running a GeForce 8800 GTS 320mb, an intel Q6600, 2gb - 4gb of ddr2 800 memory. I plan to have a mid range sound card, 1 dvd burner, and that is about it. I know there are more components, but that is all for the biggies.
I was planning to go around 700 watts, I think I may have estimated high, but I will let you experts be the judge of that. The only thing is that while looking for a good case and power supply I learned that this could easily break the $200 mark just for the two, and I was wondering if anyone had any ideas. The case may be something where I can go for a cheaper one and I'll just have to deal with it when I am assembling, but the power supply is something that I wouldn't want to cut corners on quality so much, but they are just so darn expensive. Any suggestions, insight?
Currently I am looking at the XCLIO GREATPOWER X14S4P4 750W ATX12V 750W Power Supply
http://www.newegg.com/Product/Prod [...] 6817189011
Related Product
U win some, the rest u smoke
Profile: old hand
More Information
I run pretty much that sys and ive got a 650W
No dramas with it.
That psu calc thingy suggests ~600w for that OC sys.
Its always wise to go a BIT higher
A.) as a psu gets older its rating can drop a bit
B.) as u push ur psu harder is loses effeciency and lifespan too.
IMHO, if u get a REALLY good psu, 600w absolute min, an average brand, maybe 700w
Q6600 B3 3.0Ghz @ 1.125v load
4850
P5B-D
8Gb 800mhz
Profile: journeyman
More Information
Anyone have any ideas on a brand or specific power supply.
Profile: enthusiast
More Information
I have a seasonic 650W 80+ s12 model and am running basically the same system but in SLI:
C2D e6750 @2.66 (no OC)
ASUS Striker Extreme
2GB Corsair XMS2 800 DDR2
1 DVD
1 xfi extreme gamer
2X eVGA 8800 GTS 320 in SLI
5 case fans
everything is running great, so you may want to check the article written by...I forget his name, but it is regarding PSU's and the best ones for an application (long post you cannot miss it) and pick the one that meets your requirements there, or buy the one I have, it is great.
Profile: old hand
More Information
I recommend reviewing these links:
http://www.jonnyguru.net/forums/showthread.php?t=1460
http://www.xtremesystems.org/forum [...] p?t=108088
The first recommends some specific mid range PSUs, The sight also has detailed reviews on many good PSU.
The second ranks a lot of PSUs so you can select a good one at a price you are comfortable with. It also has good forums that address PSUs among other things.
For a general discussion of power supplies and further links, try:
http://www.tomshardware.com/forum/ [...] wer-supply
Finally, to calculate requirements for your system, you can use the calculator at:
http://www.extreme.outervision.com/psucalculator.jsp
Profile: old hand
More Information
You might also want to consider this list of rankings for high-end gaming systems:
http://www.jonnyguru.net/forums/showthread.php?t=103
Profile: enthusiast
More Information
I haven't been able to take XClio seriously after they made this case:
http://www.newegg.com/Product/Prod [...] 6811103008
My personal favorite power supplies are OCZ and Antec
these might work for you:
http://www.newegg.com/Product/Prod [...] 6817341002
http://www.newegg.com/Product/Prod [...] 6817371011
Google Ads
