Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > Ethernet Wireless abd Wireless USB
I have a desktop PC cabled to a DSL modem via Ethernet. I recently acquired a DVR from DirecTV. The DVR has an Ethernet port and I have a spare USB port on my PC. If I installed an Ethernet to Wireless adapter in the DVR and a Wireless to USB adapter on my PC, would the DVR be able to connect to the Internet via my PC connection using the MS software (no router)?
Sponsored Links
Just get a router. It would be much easier than using ICS.
Grumpy
Reply to Grumpy9117
I'm more interested in cheap rather than easy.
Reply to macnext1
- 0 +
Internet Connection Sharing is not ideal.
For a cheap router look at secondhand (e-bay, flea markets, swap meets etc) there are lots of ex-ISP routers kicking around due to customer churn. Some need to be reflashed back to retail version of firmware but this is usually do-able. Obviously minimum should be 802.11g wireless standard -- personally I favour Netgear but hear good things about Linksys.
Reply to fihart
A router costs the same as a wireless USB adapter. How much cheaper can you get?
Grumpy
Reply to Grumpy9117
I would need a an Ethernet wireless adapter on both ends plus a router versus 1 Ethernet wireless adapter and 1 USB wirelesss adapter.
Reply to macnext1
Move the DSL modem close to the DVR. Get a wireless router and connect it to the DSL modem. Connect the DVR ethernet port to the wireless router. Get a USB wireless adapter for the Desktop PC and connect to the wireless router.
Grumpy
Reply to Grumpy9117
I failed to mention (wasn't really relevant) that I also have a satellite modem (very large piece of equipment) that gets plugged into the Ethernet when I have trouble with DSL. So your suggestion would require moving the DSL modem and the satellite modem into my den. Not practical for me do that (my wife would want to kill me).
Reply to macnext1
Then only move the DSL modem and leave the satellite modem in place. Connect it using ethernet when your DSL is down. If you really want to use ICS, have at it! I've tried to set it up and it's a PIA!
Grumpy
Reply to Grumpy9117
There are 507 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
