Can anyone give me a suggestion on what to do before i Return this whole lot of items.
Just purchased:
GB ga-p35-ds3l Board
evga 8800 GTS PCI-e
Going from an old frys combo deal with a crappy ecs p4m800 board
Anyways, I transfered my OCZ PC@-6400 ddr2 ram onto the board, transfered the e4300 with stock cooling and new layer arctic silver compound to the board. Made sure everything seated well.
Plugged in the 24pin atx as well as the 4 pin 12v cpu power.
Installed the 8800gts and plugged in pcie power (Antec 500w Eathwatts)
plugged speaker cable to mainboard
started system, All fans spin, no post to Monitor
Removed memory and started system, 3 beeps followed by consistent beeps.
Both memory and cpu functioning fine in older board
remove video card and start up, fans spin on cpu but no beeps. Is that normal? i've only used agp boards previously and i always thought mainboard give an error beep code when essential components are missing.
Tried one memory stick at a time. fans just spin but no post to monitor.
tried plugging in a windows drive. Can feel hard drive spinning, but it doesnt seem to be booting or actually accessing data on the drive.
Could this be a dead Motherboard? I thought it was power at first so i upgraded to the antec from an old oem powmax pos 480w power supply to no avail
I do not have any other ddr2 or another pci-e board to test with. Should i just return the whole lot and try again? Could the video board be bad, the Mainboard DOA, or is it likely that the memory, while working, is just incompatable with this board for some reason. Any suggestions would be helpful. i've been searching various forums, but can't find any problems exactly like mine, just a bunch of similar ones where they usually forget to plug iin the 12v 4pin power
cable.
Thanks for any help possible.
Badtaste2k
Just purchased:
evga 8800 GTS PCI-e
cable.
Badtaste2k
