Tom's Hardware > Forum > Graphic & Displays > Nvidia > Need some advice on settings in Nvidia Control Panel
Forum Graphic & Displays : Nvidia - Need some advice on settings in Nvidia Control Panel
Well, I know I made some configurations before I installed the latest beta-drivers that was released a couple of days ago, when the changes I made was put back to default settings. Thing is, I was guided through it so I can't really remember what I changed.
Could someone please tell me what I should change in the control panel to get best possible quality? I have a GeForce 8800GTS 640MB so I'd rather have quality over performance, at least 'till Crysis is released!
Probably something to do with AF, AA-settings. I've already changed Vertical sync to 'Force off'.
Help would be very appreciated.
Thanks in advance.
Nico
*edit*
Err, sorry. Didn't know there was a preset for highest quality possible.
Anyway, the preset put 'Use the 3d application setting' for Vertical Sync. Is this the best option or should I just leave it on 'Force Off'?
Message edited by Nico87 on 09-22-2007 at 09:01:03 PM
Sponsored Links
Put application for vsync, AA and AF. Generally you want vsync on but some games dont use it I belive.
Just set it to High Quality and most of hte other options become disbaled.
------------------------------ Na na na na na na na na HATMAN!
Reply to Hatman
There are 1290 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
