Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Problems installing fresh copy of XP
Forum Windows XP : General Discussion Problems installing fresh copy of XP
Hello all,
Having 2 errors pop up during XP installation.
I am installing on NFTS, with new partition.
57-60%, 2 errors occur
cant copy rpcrt4.dll or shell32.dll files.
How do i continue or fix?
Reply to Brandon_M
Take a soft cloth and and a few drops of water. Try to clean any dirt or smudges off the disc.
Use some duster to blow out the DVD tray.
------------------------------ CM HAF 932 / GIGABYTE GA-EP45T-DS3R / E8500 @ 3.75Ghz / 300GB Velociraptor / 4G DDR3 OCZ Reaper 1333
Saphire 1G 4850
Simple and Free Guide to Removing Malware
Reply to aford10
Hello'
I've already tried cleaning/wiping the disc.
There is nothing on it' no scratches/smudges.
Any other suggestions?
Thanks.
Reply to Brandon_M
hello,
you have to change your xp bootable cd . because i thing your bootable cd is currepted so it give error.
thanks
regards
purushottam.aher@esds.com
Reply to Anonymous
Is this a new hard drive?
Try downloading the diagnostic tool from the manufacturer's website to check the drive for errors.
If you've got another CD/DVD drive, try using that one instead.
Saphire 1G 4850
Reply to aford10
There are 2057 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 5 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
