I am planning on building a new PC and I really would like to build it with the smallest case possible without limiting my options in terms of components. At this point I am thinking of building it on a micro atx board so I can fit it in a sff case. Tentitively I want to have an intel q6600 and 8800 gts or ati radeon 2600xt but probably will not be overclocking. If i use one of the g33 (GIGABYTE GA-G33M-DS2R http://www.newegg.com/Product/Product.aspx?Item=N82E16813128053 ) chipset micro atx boards and a Silverstone SG03 case(http://www.newegg.com/Product/Product.aspx?Item=N82E16811163085) would there be a meaningful performance drop off from using a standard atx formfactor (p35 chipset) and a mid tower (http://www.newegg.com/Product/Product.aspx?Item=N82E16811204007)? Or should I just get a small tower and stick with a regular atx board? Any thoughts would be much appreciated.
Thanks.
Thanks.
