I'm having some cooling issues with my 5200+ AM2 and the stock cooler,
CPU @ 56C idle and 62C load, maximum allowable temperature is 65C and I'm hovering a little too close to the limit.
I'd like the CPU to idle around 40C and run around 50C or so under load, will any of the following coolers help me to achieve this goal....?
Or should i just to Water-Cool the CPU and be done with it...?
I really don't want to RnR the motherboard at this point, Koolance allows mounting of the CPU water-block w/o pulling the mobo and i believe a couple of these Heat-Sinks will also allow mounting w/o pulling the mobo as well.
I'll do it if i have to, i just don't want to.....
ThermalRight HR-01
http://www.newegg.com/Product/Product.asp?item=N82E16835109015
ThermalRight Ultra-120
http://www.newegg.com/Product/Product.asp?item=N82E16835109140
Tuniq Tower 120
http://www.newegg.com/Product/Product.asp?item=N82E16835154001
Folding@Home
ThermalRight HR-01
Tuniq Tower 120
Folding@Home
