I've tried DIY liquid cooling on a GA-965P-DS3 and on a GA-P35-DS3L, and both boards are now useless.
Has anybody else had problems liquid-cooling a GB mobo (I'm cooling the NB, the SB, and the RAM).
The first time I tried with the 965P, it would not turn on after I completed the cooling system installation.
Figuring I'd killed it when the coolant leaked and the PSU died a horrible death, I transfered the system to a GA-P35. It worked once. Then I plugged in all the periferals and it never powered up again (and yes, I've tried pulling various parts and unplugging all but the bare minimum needed to run the PC)
At this point, God reached out and touched the 965P, and it worked again, so I transfered the cooling system back.
Now it powers up, but gets stuck partway through the POST and so it just sits there until you turn it off.
Has anybody else had a Gigabyte mobo mysteriously die after modifying it for liquid cooling? Are they unusually vulnerable to breakage when you remove the heatsinks to attach the cooling blocks?
The circuit city guys tell me that the P35 probably isnt turning on because it's NB is dead.
-M4F
-M4F
