Hi all, I've just moved from Hawaii to CA, and my computer has been in transit for about 6 weeks or so. When it was shipped, all the water was drained out, reservoir/radiator disconnected, and most of the tubing was disconnected with some paper towel pieces stuffed into the ends (to prevent any extra liquid built into the water blocks from spilling onto components.)
Now I'm about to get it back here in a day or two, I'm redoing the water loop to hopefully make it more efficient, using a different coolant, putting in all new tubing, and installing some coolsleeves, etc.
So my question is, do i need to flush the system? And if i do, where should i go for a tutorial on how to do it.
Keep in mind, that some remnants of fluid will have been sitting in there during transit, and i didn't flush the system when I very first put it together, although I don't think anyone does.
If having minute amounts of the old fluid mixed with the new fluid isn't a problem, I'll probably skip the flush, because i figure it will be a big deal.
thanks for your help.
