hi, i'm new to this forum, came here looking for some answers
i have a DFI km400-mlv rev.B mainboard, i used to have an AMD athlon 1800+ in it, i'm trying to upgrade to a AMD barton 2800+ , but on POST it reads as 600MHZ unknown processor, i've tried flashing the bios to the newest version and looked at the manual for the board to see if i needed to change any jumpers or anything, but cannot find anything. DFI's website claims the board supports this CPU. I'm at the end of my rope here! any insight on this problem is greatly appreciated.
also, the rest of my system specs: 400w psu, 1 gig pc3200 ram, geforce 6200 video card
You must have a mobile cpu, with unlocked multiplier. Try setting the multiplier at 10, and the cpu fsb at 200. You can also try changing the cpu voltage if you want to try overclocking. But you'll need a good heatsink. Bartons run hot when overclocked.
Unfortunately, there is nothing you can do. The DFI km400-mlv does not allow you to overclock. Without any overclocking features you cannot change the FSB or the clock-multiplier. In other words, that Athlon XP-M 2800+ is stuck at 600MHz.
Basically that means you need to find a Socket A m-ATX motherboard (assuming you have a m-ATX case) that will allow you to overclock. That's not an easy feat anymore.
If you can, then get a refund on the XP-M.
------------------------------Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
