Having trouble upgrading my memory from 2 x 512mb pc3200 ddr 400 to 2x 1gb pc3200 ddr 400.
The motherboard just hangs after I have installed the new RAM, and I have tried switching them around, mix combos of new and old, singlular etc to no success.
My motherboard is Jetway A350DMS - I have a sneaky suspician that it could be due to the CAS Latency setting... but i'm insure if my motherboard can support 3.0 CAS Latency.
Mobo manual at :
http://download.jetway.com.tw/download.asp?sorder=Name&sword=A350DMS
Memory Specifications:
Up to 3.2 GB/sec of peak bandwidth using PC3200 DIMMs (with DDR400 memory chips).
JEDEC Standard.
184 pin DIMM,
non-ECC.
DIMM Lead pitch: 1.27 mm. 2.5 Volts. SSTL-2 I/O Interface. SPD Support. Support for Memory Chip Stacking.
Mobo manual at :
JEDEC Standard.
184 pin DIMM,
non-ECC.
