Tom's Hardware Forums » Storage » NAS/RAID & Technologies » Programmer acting as IT staff ... HELP!
Word :   Username :
Bottom
Author
 Thread : Programmer acting as IT staff ... HELP!
Profile: stranger
More Information
Hello,
We are currently working on building a new file-server. The biggest problem is that I am a programmer and only know enough about hardware to get myself in trouble. :) We are not so much in need of performance but of fault tolerance. So I am planning on using raid 1 mirrors.
Two biggest questions are:
1.) Should I use onboard raid controller or have it separate from the motherboard. My concern is if the motherboard fails, we will not be able to recover the data on the raid drives. Along with this, should I purchase two of the raid controllers in the event that the first fails. More broadly speaking, are raid controllers universal or manufacture/model specific.
2.) I plan to do two raid configurations: One raid set for the operating system and one for the data being served. Any recommendations or issues that can be given would be appreciated.
Related Product
Profile: enthusiast
More Information
RAID 1 drives can normally be moved to any machine and will work as "normal" drives when connected to its native controller. Please read this http://www.tomshardware.co.uk/foru [...] et-servers then post any questions.
UD
Profile: stranger
More Information
Thank you for this link ... that helped me allot. However, your reply confused me just a bit. Does "native controller" mean the same controller (brand/model) as the raid was originally created with? If so does this mean that if the original controller failed then we would need another controller with of the same brand to recover the data?
Profile: enthusiast
More Information
Hi platics,
Sorry for the delayed reply.
Trying to keep it simple!
What I mean is that when you connect a hard drive to the motherboard there are is a chip that handles communication between the two. This is what I call native connection. When you have a RAID array you will still need the connection between the hard drive and the motherboard but you will need a chip "in-front" of the connection to perform your RAID functions. The RAID function that is performed on the chip depends on the RAID array that you have configured.
I'll compare RAID 0 and 1.
In RAID 0 the chip needs to take any information that you want to write to the disk and split it in half, then send half of the data to each disk in your array. When you read data the chip does the reverse, it will add the two "pieces" of information back together. If you took one of those drives and connected it to a native connection no usable information could be retrieved as the drive only holds half the data.
With a RAID 1 array the chip makes sure that the same information is written to each hard drive so there is no need to split or reconstruct any information. Since there is no need to reconstruct the information on the disk we are not dependent on a RAID chip to read the information on the drive, I can take the drive and connect it to a native controller and read everything off the drive.
There are differences in RAID implementations by different manufacturers so there is no guarantee that a RAID array that has been built on one brand will work on another. You would need to do your homework.
I hope this answers.
UD.
Profile: stranger
More Information
Thank you, that cleared it very specifically and was exactly the answer that I was looking for. :bounce:
Profile: member
More Information
Typically the add in RAID controllers work better but tend to cost more. They will handle all the data processing and have cache built in on the card and will take strain off of the CPU.
Depending on how many users you will have accessing the information simultaneously would be the major factor in determining if you should use the onboard RAID vs an add in card. Intel uses its ICH9R controller on tons of boards so I would imagine they are interchangeable.
Typically you would use a RADI 1 for the OS and a RAID 5 for the data, but it really depends on what software you are going to be running.
Profile: Ancient Poster
More Information
Scruze my English!
Google Ads
News
IBM triples transistor performance with Germanium
Published on December 07, 2004
IBM has successfully demonstrated a new technique for improving transistor performance that will help the company build smaller, more powerful chips in the next decade, company researchers said Monday. Read more
HP rolls out blade workstations
Published on November 30, 2006
HP has rolled out the industry's first blade workstation which stores the computer safely away in the datacenter closet. The ProLiant Blade Workstation Solution is stacked vertically in blade chassis cabinets and several dozen can be placed in a standard 19" wide server rack. Read more
Microsoft founding programmer to head to International Space Station
Published on April 03, 2006
The Russian news agency Novosti has confirmed that Charles Simonyi, the retired Microsoft programmer who designed the word processing engine for the original Microsoft Word, and whose original concept for Multiplan paved the way for all multitasking business software to follow, will be the fourth tourist to head to space on board the International Space Station. Read more
ATI buys cable modem firm
Published on February 08, 2005
ATI said that it will pay $14 million dollars to acquire Terayon's cable model silicon intellectual property. Read more
Latest Reviews & Articles
Seagate's 1.5TB Barracuda: Bigger And Better?
Published on October 02, 2008
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
Stalker: Clear Sky - Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
