Hi all, I'm currently flushing my system, and it's really the first time I've noticed how much water my pump is pushing out.
IMHO, it's not nearly as much as it should be.
I have a Swiftech MCP-655 Pump
Thermochill 120.3 radiator
Swiftech STORM CPU Block (R2)
everything is 1/2" ID
Now the pump is rated at max 317 GPH, or 5.2 GPM. Now if i have my pump set to the "1" setting, I'm hardly moving any water at all, like my tubes won't even completely fill. If i run my pump at "5" it will fill all my tubes and stuff, but the rate of flow coming out is hardly 5 GPM, I'd say maybe not even 1 GPM. The water is flowing out, just not very much as I would prefer or hope for such a hich performance pump.
Now is this normal? Or does it look like i have something blocking my flow? i just replaced all my tubes and everything. I made sure to bleed my radiator.... I just want to make sure this is normal before i actually put my solution in and close the loop.
If i had to say 1 component that was limiting water flow the most, it would be the cpu block. I believe that if i set the pump at "1" and turn it on, most everything looks good until the water hits the CPU block. Is there anything i can do to increase the flow to it?
Well, without knowing much about your cooling loop arrangement I'll just have to assume some things here....
The component that most hinders flowrate is always going to be the radiator - due to the fittings and the tight bends and turns internally.
Now, I don't know what other components you might have in your loop or how you have them arranged but I'm just going to stick with the assumption that you just have the CPU being cooled right now.
The optimal arrangement for the loop would be:
reservoir - pump - cpu waterblock - rad - back to reservoir
This is optimal because it allows for the CPU to get the best possible flowrate right out of the pump. If you have the radiator BEFORE the block you are just killing the flowrate.
------------------------------Swiftech Mcres-Micro Reservoir, MCP655 Pump, D-tek Fuzion CPU Waterblock w/nozzle kit, Thermaltake Toughpower 1200, Swiftech Stealth GPU Waterblock, 2 external dual 120mm rads (each with four 120mm fans in "push-pull" )
Reply to phreejak
I really don't think that my rad. is the flow rate restrictor.... I accidentally forgot to put my radiator bleed cap on when i started the final flush with distilled water. Turned the PSU on, noticed some weird sounds, and water shot out of my radiator and hit the ceiling.
And here's a picture of the flow rate at the end of the loop:
well, I closed off the loop and put the new liquid in, and the flow was at a crawl. So i disassembled the storm block. there were a couple clogged jets, but it didn't seem all that bad to me.
i did hook up a spare piece of tube to it and chambered about 2 feet of water, and blew as hard as i could, and watched the water slowly drain out. I"m surprised this block can be effective.
