Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Need info on parts for diy mini-ITX RAID5 server
Forum Homebuilt Systems : General Homebuilt - Need info on parts for diy mini-ITX RAID5 server
Hey all, I figured i'd post up to see if anyone here knows any inf regarding parts I need for a new fileserver I want to build.
I have already built a RAID5 fileserver: http://diynas.wetpaint.com/?t=anon and this time around, I want to build something a little smaller and faster using 5 large drives and a mini-itx motherboard. My current build has a read/write speed of 100MB/S probably due to the bandwidth of the PCI bus. On this new build I would like to use a PCI-E RAID card to increase the read/write speed. The problem is, I cant find a mini-ITX form factor motherboard with PCI-E, and I am not sure what case to go with. I would like to go with a custom made marriage of a small cube case and a 5-bay SATA hotswap cage. Does anyone have any ideas or links of similar projects I can use? Thanks!
Sponsored Links
I think I found one example of what I am trying to do, I found a project called "UDAT" by a modder named Mashie. Heres a page illustrating it:
http://www.epiacenter.com/modules. [...] =56&page=2
I have another question though, it seems he is using the RAIDCore BC4852 controller card which is PCI-X. Mashie has it plugged into a regular PCI slot on the motherboard. Would a setup like that run at the PCI bus's bottleneck of 100MB/s? I would really like to realize a higher speed than that.
Reply to snootch
yes that will slow it down a lot as you will be useing the same pci-33 bus as other on board chips like the network on some chipsets.
You need a pci-e one and put in a pci-e x4 or faster slot.
this board has
http://www.windowsfordevices.com/n [...] 75767.html
2 PCI-X-compliant PMC (PCI Mezzanine Card) sites
http://www.linuxdevices.com/news/NS8584188259.html
Message edited by Joe_The_Dragon on 09-08-2007 at 06:57:29 PM
Reply to Joe_The_Dragon
Thanks for the info. I really want to go PCI-E instead of PCI-X if im going to buy 2TB of HDD's though. I think I am going to abandon this plan, and instead bundle these storage capabilities into a HTPC. Now i've got no problems with finding PCI-E since now i'm dealing with a full ATX board. I'll create a new thread for those questions though. Thanks for the replies!
Reply to snootch
There are 1101 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
